SOHC clutch question!!!!
Old Apr 6, 2003 | 09:05 PM
BoostedSOHC's Avatar
Default SOHC clutch question!!!!
I am going to be boosting soon and i wanted to know what clutch you guys would recommend for around 8psi on a d16y8. i have heard great things about ACT and clutchmasters, as well as bad things about both so i was wondering what your opinions were! thanks for the input!
Old Apr 6, 2003 | 11:02 PM
Kataku2K3's Avatar
Default Re: SOHC clutch question!!!! (BoostedSOHC)
I will always recommend ACT... As I posted in here https://honda-tech.com/zerothread?id=465982 you can see how I feel about Clutchmaster... Even tho I don't work with SOHC's that much the first clutch I ever installed was on my friend's D16Z6 in his EG... That was 3 years ago and the clutch is still holding up just fine after squeezing squeezing and more squeezing... hehe It's just an ACT Heavy Duty PP with 6 puck disk... You should be fine with that but if you want a bit more holding power then go with an Xtreme PP... Good Luck and let me know if you need anything else...
BlackCRX
Feb 18, 2005 08:07 AM
ieatrice
Jul 29, 2004 07:26 AM
scttydb411
Jun 21, 2003 03:32 PM
