distributor question
Old Apr 6, 2003 | 12:03 PM
street dreams's Avatar
From: chillin in that city called queen creek, but homes the atl
Default distributor question
ok my distributor is throwing a code 8 check engine light. and a code 8 stands for tdc sensor now my question is can u just change the tdc sensor out of the dist. and if so witch sensor is it and is this possible and to this is for a 95 obd1 gsr dist. and the reason i am asking is that i have a 01 obd2 gsr dist. lying around and wouldn't mind just switching the parts around
Old Apr 7, 2003 | 04:48 PM
Default Re: distributor question (streetdreams02)
come on people
Old Apr 8, 2003 | 10:13 AM
JimBlake's Avatar
I remember somebody saying the individual sensors aren't available, but I don't know that for sure. I suppose TDC is the one with 2 points on the distributor shaft.
Old Apr 9, 2003 | 06:30 PM
Default Re: distributor question (JimBlake)
anybody else
Old Apr 9, 2003 | 07:35 PM
Blaze45's Avatar
Brrraaaap!
Is your timming set properly? that could be a problem, and maybe your timming belt has skipped a tooth? just somethin to think about
Blaze
Old Apr 9, 2003 | 08:35 PM
psi420's Avatar
Default Re: distributor question (Blaze45)
If the sensor is bad, replace distributor.
You can get remanufactured ones from dealer or auto parts store.
Old Apr 10, 2003 | 04:01 PM
Default Re: distributor question (psi420)
distributors cost 200 250 fort a 94-95 gsr i just want to see before i have to buy another can i fix the one i got because i have an 01 gsr distributor lying around and i wanted to see if i could just switch that sensor and were in the distributor is this sensor
Old Apr 10, 2003 | 06:25 PM
Neukin's Avatar
wht/blu and the org/blu wires go to the tdc sensor so trace it and find it. id just try it if it doesnt work just put the part back in the otherone.
Old Apr 11, 2003 | 06:30 PM
cool thanks man finally an answer
Old Apr 12, 2003 | 04:18 PM
blacksheep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetdreams02 &raquo;</TD></TR><TR><TD CLASS="quote">distributors cost 200 250 fort a 94-95 gsr </TD></TR></TABLE>
I'm just wondering where you can find one for that cheap?
Old Apr 17, 2003 | 06:50 PM
Default Re: distributor question (blacksheep)
check out ebay
Old Apr 17, 2003 | 07:27 PM
tegmaniac's Avatar
If you have an exra GSR distributor just use that one. I believe they have the same number of wires. 9 total. All you have to do is change the connector by taking out the pins. obd1 uses 2 connectors. One with 2 wires and the other with 7. ob2 just has 9 all in one connector. I'm about to put a 2000 si dist. In my obd1 teg for ls/vtec. Hope this helps.
Old Apr 18, 2003 | 06:41 AM
sailor's Avatar
how bout a tdc sensor on a 97accord? its inside the crank? how do i go bout changin this??
B16EJ
Mar 16, 2015 07:41 PM
PreClude
May 30, 2011 04:46 PM
ECICivic
Apr 3, 2005 04:51 PM
Slatelude
Oct 13, 2003 05:26 PM
