Auto meter oil guage install
Old Apr 4, 2003 | 09:47 AM
Gs-RAW's Avatar
Default Auto meter oil guage install
I need to know what size of the fittings are for the existing oil pressure switch. How much steel braided line i need, and what the fittings and such i need. Its a sport-comp electrical guage. Thanks for the help.
Old Apr 4, 2003 | 09:56 AM
See Are X's Avatar
Default Re: Auto meter oil guage install (Gs-RAW)
need to know also...and will a oil pressure gauge tell you if you're running low on oil? less oil=lower oil pressure?
Old Apr 4, 2003 | 10:31 AM
Luke J's Avatar
Default Re: Auto meter oil guage install (See Are X)
Yea
Old Apr 4, 2003 | 12:45 PM
vactor's Avatar
stock thread on the block is 1/8" BSPT. you can get e 1/8" BSPT -> 1/8" NPT adapter from autometer. make sure not to hang the sender off the block, as it will break off. run lone hose to the firewall and install a T fitting there. screw stock sender into T, screw autometer sender onto T, zip tie the T to the firewall. low oil pressure is indicative of an oil leak, bad pump and low oil. it's a great safety gauge to have!! p.s. the autometer sender needs to be grounded, make sure not to foget to do that.
EFsideways
Jan 1, 2008 01:52 PM
afplayboy17
Oct 6, 2007 10:39 AM
RACEPAK
Jun 4, 2006 02:34 PM
W O T
Jan 29, 2005 08:01 PM
Nextelbuddy
Jul 13, 2003 07:44 PM
