Is this Radiator Single or Dual Core?
Old May 13, 2006 | 01:41 PM
Propulsion's Avatar
Default Is this Radiator Single or Dual Core?
This came on my DX but Im not sure if the previous owner replaced it (he had a ls swap)
Enough cooling if I go H22?
Modified by Propulsion at 5:16 AM 5/14/2006
Old May 13, 2006 | 02:33 PM
civic_fan's Avatar
Default Re: Is this Radiator Single or Dual Core? (Propulsion)
looks like a single core for an automatic.
Old May 13, 2006 | 11:24 PM
Propulsion's Avatar
Default Re: Is this Radiator Single or Dual Core? (civic_fan)
can anyone confirm this?
Is the auto radiator enough for a H22
Old May 14, 2006 | 07:29 AM
mec. pedri's Avatar
i've done numerous h22 swaps with a civic radiator
haven't had a problem yet
Old May 14, 2006 | 08:21 AM
Brick Top's Avatar
looks like a dual core to me. del sol b16. yes, that is plenty for your h series.
Old May 14, 2006 | 09:50 AM
Relic1's Avatar
100% positive it's a dual core.
Old May 14, 2006 | 07:38 PM
Propulsion's Avatar
Default Re: (Relic1)
sweet, how can you tell?
Old May 14, 2006 | 08:03 PM
Jim Truett's Avatar
Default Re: (Propulsion)
look through the radiator cap. If you see two rows of tubes, it's dual core.
Old May 14, 2006 | 08:06 PM
Propulsion's Avatar
Default Re: (Jim Truett)
There are 2 rows, but they are joined together right?
Old May 14, 2006 | 10:06 PM
.God.'s Avatar
that'll work just make you have enough fan behind it if you boost the H22.
Old May 15, 2006 | 10:47 AM
Propulsion's Avatar
Default Re: (..Lloyd Braun..)
Good stuff, Im planning just NA, so this should be enough even w/ the stock fan right?
Old May 15, 2006 | 01:52 PM
powerofdreams8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Propulsion &raquo;</TD></TR><TR><TD CLASS="quote">Good stuff, Im planning just NA, so this should be enough even w/ the stock fan right? </TD></TR></TABLE>
The stock fan actually works better then most of the less expensive aftermarket thin fans.
Old May 15, 2006 | 02:43 PM
R.S.AKIMOTO's Avatar
* B A N N E D *
Default Re: (powerofdreams8)
yep...its the dual core.
Varano44
Sep 17, 2008 05:14 AM
CivicSH
Aug 25, 2007 05:22 AM
Propulsion
May 15, 2006 02:02 PM
nmudrumline
Sep 20, 2005 03:15 PM
chewiejdh
Jun 29, 2003 04:36 PM
