valve spring/retainer compressing question.
Old May 13, 2006 | 04:19 PM
swatteamtimmah's Avatar
Default valve spring/retainer compressing question.
What Valve Spring Compressor are you guys using? I went and purchased one from Sears today and I cant seem to get it to angle properly is there a different kind/version i can pick up that will make the job easier?. Are there any Tips/Tricks to it?
The one i bought is this one http://www.sears.com/sr/javasr...e=Yes
Old May 13, 2006 | 04:57 PM
turtleman321's Avatar
Default Re: valve spring/retainer compressing question. (swatteamtimmah)
it says it has two different jaws. one offset and one regular did u try both?
Old May 13, 2006 | 11:56 PM
Default Re: valve spring/retainer compressing question. (turtleman321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turtleman321 &raquo;</TD></TR><TR><TD CLASS="quote">it says it has two different jaws. one offset and one regular did u try both?</TD></TR></TABLE>
i did and had a hard time with both.
Old May 15, 2006 | 02:10 PM
anyone? is there any other designs or a honda specific one to make this easier?
Old May 15, 2006 | 10:30 PM
JDM_EK_JOE's Avatar
i've never seen a valve spring compressor that looks like that.
Old May 16, 2006 | 04:20 AM
Default Re: valve spring/retainer compressing question. (91Civic_Joe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91Civic_Joe &raquo;</TD></TR><TR><TD CLASS="quote">i've never seen a valve spring compressor that looks like that. </TD></TR></TABLE>
what have you seen/used cuz the only other "kind" im seeing is the Snap On one and thats like $120...
Old May 16, 2006 | 07:38 AM
JDM_EK_JOE's Avatar
I think the one i saw id used for domestic cars and u have to bend the tabs that push down on the spring inwards (&gt;&lt
Old May 16, 2006 | 10:01 AM
downest's Avatar
You want this, and this is how you modify it for the Honda engines:
Old May 16, 2006 | 02:34 PM
havok hybrid's Avatar
Default Re: valve spring/retainer compressing question. (downest)
SNAP-On makes one for honda & acura's. its $119 bucks. I own one and its great.. just the head needs to be bolted or fastend down.
Old May 16, 2006 | 09:23 PM
brokeHonda's Avatar
Default Re: valve spring/retainer compressing question. (havok hybrid)
Knock off version of the snap-on,
http://cgi.ebay.com/ebaymotors...wItem
Equally effective for the job yet half the price!
Old May 16, 2006 | 11:13 PM
Combustion Contraption's Avatar
That is a great kit but a little difficult if off the car. If the cylinder head is off the car i recomend the C-clamp type, pneumatic if you can afford it. The snap on style is great to use with an air compressor as well, you can get a hose with a fitting on the end to fill the cylinder with air, then compress the valve spring, and the compressed air in the cylinder will keep the valve from dropping.
Timo2
Feb 14, 2014 08:54 AM
JDM_SOHC
Mar 23, 2012 01:42 PM
Dunc
Oct 20, 2007 07:02 PM
2fknlo
May 6, 2003 06:49 AM
