Clearing monitors on ECU.
Old May 14, 2006 | 10:51 PM
chihuahuamanx's Avatar
Default Clearing monitors on ECU.
I failed smog because my ECU's monitors were just reset after i pulled the battery power. The smog tech said that i needed to drive the car while the ECu monitors reset. I checked with my code scanner, and it says that the evap monitor scan is incomplete. what do i need to do to get the evap to get checked out.
thanks, let me know if you have any questions.
Old May 15, 2006 | 06:19 AM
Default Re: Clearing monitors on ECU. (chihuahuamanx)
bump
Old May 15, 2006 | 07:39 AM
thesmogman's Avatar
Your are not clearing the monitor. You are setting it to completed.
However to pass smog in CA not all monitors have to be set. It is usually 6 of the eight monitors.
For the evap monitor... check your gas cap and make sure it is tight.
There are drive cycles specified by the manufactures to complete these monitors, You can check into this. Sorry, I don't have access to get you what you need to do.
Old May 15, 2006 | 08:11 AM
EE_Chris's Avatar
You're just going to have to drive the car around, in varied conditions, over a few drive cycles. A drive cycle is NOT simply cycling your key from off/on/off.
Old May 15, 2006 | 05:09 PM
Default Re: Clearing monitors on ECU. (EE_Chris)
yea, ive been driving it to random *** places and home, I was just wondering if someone had a source that would tell be what cycles needed to happen b4 the evap was completed.
Old May 17, 2006 | 04:18 PM
anyone know if the evap monitor needs to check out vbefore i can smog here in cali? The shop doesnt pick up their phone.
Old May 18, 2006 | 03:43 AM
EE_Chris's Avatar
I'd say more than likely - yes.
OBD2 mandated that a pinhole (.040") be detected in the EVAP plumbing, so I'd say yeah it needs to run.
Old May 18, 2006 | 10:02 AM
thesmogman's Avatar
To reiterate again!
Oh Yeah, Drive cycles To count as one drive cycle the car has to be colder than 160deg. and driven over 160deg. to start another drive cycle the car has to cool down below 160deg again.
jxhxb
Honda Civic (2001 - 2005)
Dec 24, 2021 04:46 AM
Sinology
Oct 20, 2009 03:57 PM
le0ftw
Sep 11, 2008 10:30 AM
RI_TM
Apr 3, 2008 12:09 PM
stockegsix
15
Aug 3, 2005 02:11 PM
