what do u guys think?
Old May 13, 2006 | 10:14 PM
hialeahzbg's Avatar
Default what do u guys think?
will a hi flow fuel rail and 310cc injectors make a difference on my lsvtec...im currently running on stock b16 fuel rail and injectors...also am i going to feel any power with aftermarket cam gears or is it just for tuning purposes....
Old May 13, 2006 | 11:00 PM
hialeahzbg's Avatar
come on HT help a brother out...
Old May 14, 2006 | 05:08 AM
Runnerdown's Avatar
Default Re: what do u guys think? (hialeahzbg)
high flow fuel rail is worthless for all except some of the high hp turbo cars
the injectors are only necessary if you are running lean and cannot flow any more from stock ones. If you put on 310cc the car will NEED to be tuned or else it will run like crap
yes, cam gears are a tuning tool.
Old May 14, 2006 | 07:52 AM
hialeahzbg's Avatar
so i shouldnt waste my money on any of those items?
Old May 14, 2006 | 08:05 AM
Runnerdown's Avatar
Default Re: (hialeahzbg)
list all the motor parts and specifications. and has it been tuned at all.
Old May 14, 2006 | 08:22 PM
hialeahzbg's Avatar
stock b16 head with skunk2 manifold and type r throttle body...iceman intake....ls block with b16 pistons 98+ jdm type r cams ....dc jdm 4-1 headers and hks hi power exhaust...aftermarket FPR....chipped ecu...
Old May 15, 2006 | 01:31 PM
Ruben19's Avatar
you should be fine with the stock injectors.
you dont need a fuel rail
Old May 15, 2006 | 08:34 PM
hialeahzbg's Avatar
so when will i need a fuel rail, injectors and gears?
Old May 15, 2006 | 08:43 PM
Runnerdown's Avatar
fuel rail, when you have a setup capable of hundreds more horsepower then you have now. Injectors I already said and cam gears usually when you have aftermarket cams. Be aware, many things in the import market are flashy bling, or just silly gimmicks to make money. things like fuel rails, fancy spark plugs wires etc..
Old May 15, 2006 | 09:13 PM
hialeahzbg's Avatar
what else should i do besides a hondata and tuning...
crx.com
Jan 4, 2006 06:36 PM
Tapen00n
Feb 7, 2005 06:45 PM
CivicHB89
Jan 2, 2005 09:09 PM
b16delsol
Feb 3, 2004 07:40 PM
ITRSpeed
Feb 3, 2004 03:42 PM
