O2 Sensor heating up slowly
Old May 16, 2006 | 07:24 PM
Ri5e's Avatar
Default O2 Sensor heating up slowly
I replaced an old O2 sensor (bad) with a new one and now the new O2 sensor takes a while to heat up and it is oscillating on the lean side. Could this be a wiring issue? Bad ground?
Old May 17, 2006 | 08:23 AM
thesmogman's Avatar
Default Re: O2 Sensor heating up slowly (Benen Man)
How fast is it oscillating? 8 - 10 a second is correct. As for it being on the lean side you need to go elsewhere. Ask yourself, What would make it run lean other than the computer. Vac leak, low fuel pressure, Stuck injector, bad air temp sensor, bad coolant temp sensor, etc...
I shouldn't say bad but out of calibration is a better word for it.
Civicman86
Apr 30, 2006 02:20 PM
Maxime
May 17, 2004 11:30 AM
hondave
May 2, 2004 09:36 PM
zseeanz
Nov 5, 2002 05:15 AM
Slow Egg
Oct 6, 2002 10:57 AM
