How to turn over engine?
Old May 12, 2006 | 01:11 AM
93CamaroLT1's Avatar
Default How to turn over engine?
Ok.. say you pull the balancer bolt out and then pull off the timing cover and you are not at cylinder 1 TDC (this is on a car where the balancer isn't "keyed"). Can I just put the balancer bolt back in without the balancer and then turn the engine over to get it back at TDC on cylinder 1 and then just throw a strap wrench over the end of the crank shaft (to hold it) and pull the bolt back out???
Old May 12, 2006 | 10:10 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: How to turn over engine? (93CamaroLT1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93CamaroLT1 &raquo;</TD></TR><TR><TD CLASS="quote">(this is on a car where the balancer isn't "keyed")</TD></TR></TABLE>
Old May 12, 2006 | 10:39 AM
thesmogman's Avatar
Default Re: How to turn over engine? (LSVT3K 91 C1V1C)
Is it a stick? Put it in gear and rock away
SirFerret
Honda CR-V & Element
May 18, 2018 05:53 PM
MalcolmV8
Sep 27, 2012 05:10 AM
djkurious
Sep 13, 2009 11:43 AM
kess
37
Dec 2, 2004 09:21 AM
imaginary17
May 10, 2004 09:12 AM
