How to Recalibrate gauges??
Old May 14, 2006 | 10:06 AM
jfruauff's Avatar
Default How to Recalibrate gauges??
My boys got a prelude and he stopped buy to ask why car wasnt redlining anymore. I drove it and could tell cat was redlining but gauge was obviously wrong. I noticed that he put the white gauge cover on his stock gauges. I asked him if he pulled the needle and he said yes. I know thats bad. My question is how do I recalibrate the stock gauge to make it perform correct again...
Old May 14, 2006 | 04:43 PM
EG2Driver's Avatar
Default Re: How to Recalibrate gauges?? (jfsrt4)
i need to know too.....stupid backlit gauges.....What a waste of money.
Bump
Old May 15, 2006 | 03:32 PM
jfruauff's Avatar
bump I heard its hard and that you had to take it to a dealer. Should I just tell him hes better off finding a used stock gauge cluster..
Old May 15, 2006 | 03:39 PM
Dogginator's Avatar
Daisy... Daisy...
You could connect an external tachometer and adjust your tachometer needle position to match. For the speedometer, get a GPS and adjust the needle position.
Old May 15, 2006 | 04:24 PM
Relic1's Avatar
function generator or a waveform generator will produce the signal needed to move the gauge to the point you want.
some math and searching through the Helm manual will tell you what frequency, voltage and offset is needed.
to do it a little ghetto-ish, pull of the clear face and reinstall everything.
use an external tach and GPS like mentioned above.
Also fill the tank and make sure the fuel gauge isn't off.
same applies to the temp needle. Drive around for 10-15 minutes, you should be in the middle.
zccr-xsi
Feb 26, 2006 05:17 PM
Teamdiesel
Feb 19, 2006 09:28 AM
Capt. Jimbo McSubipants
Jul 7, 2005 05:25 PM
even91civic
Jul 22, 2004 01:20 PM
