Remove head or use valve spring Compressor?
Old May 13, 2006 | 10:04 PM
j spec's Avatar
Default Remove head or use valve spring Compressor?
Just getting ready to install some springs and retainers in my gsr wondering which way would be easier and simpler. oh ive never pulled the head off before and if i pull the head i'll be buying arp studs and headgasket. thanks
Old May 14, 2006 | 09:53 AM
JDMTurboEG6's Avatar
Default Re: Remove head or use valve spring Compressor? (roma's GSReg6)
easiest way is probably to do it with the head on but you have to worry about keeping the valves in the head when swapping everything over. best way is to put each cylinder at tdc when taking it aport and fill the cylinder up with compressed air to keep the valve in place.
Old May 14, 2006 | 01:14 PM
j spec's Avatar
Default Re: Remove head or use valve spring Compressor? (JDMTurboEG6)
i already have a tool rigged up that threads into the spark hole and has a fitting for a comressor hose on the other end i can use. is it straightforward besides that?
Old May 14, 2006 | 02:54 PM
yea its pretty much straight forward after that. just take out the keepers and swap everything over and put the keepers back in.
90AccordVTEC
Jun 22, 2006 04:51 AM
dkk119
Mar 13, 2006 06:27 PM
qcktegls
Nov 17, 2004 10:19 PM
Steve91
Sep 19, 2003 11:53 AM
jabroni95gsr
Nov 19, 2002 08:17 AM
