Oh SHIT!! Why my cams look like this!!!???????
Old May 31, 2004 | 09:41 PM
leadfoot78's Avatar
Default Oh ****!! Why my cams look like this!!!???????
I decided to check my valve clearance today and got a look at my cams. They are 2001 spec ITR cams, I bought them brand new and after like 15k miles they look shitty. I took pics, does anyone know what this is, it looks like low oil, or low oil pressure, but I have never had problems like that. This is a perfectly running GSR, it put down 177whp and 129wtq half a year ago, very well taken care of. I can't feel anything on the lobes with my finger, nothing catches with the nail, but it looks bad!
Old May 31, 2004 | 09:51 PM
Lord Helmet's Avatar
Default Re: Oh ****!! Why my cams look like this!!!??????? (leadfoot78)
possible problems could be the gridle plate torqued in wrong sequence causing the lobes to brush against the plate. or not enough break-in lube for the cam. or you have some particles that got into the cylinder head.
Old Jun 1, 2004 | 12:39 AM
mh's Avatar
mh
If its just that one lobe thats, damaged I'd check the oil nozzle plates or whatever their called. Anyways i'm refering to the plate that's sitting just above the cams. one of the holes may be clogged.
Old Jun 1, 2004 | 04:39 AM
HotWheelz's Avatar
Default Re: Oh ****!! Why my cams look like this!!!??????? (mh)
check your lost motion assemblies they might be binding....
Old Jun 1, 2004 | 06:53 AM
RedlinedVTEC's Avatar
Did you use alot of lube when you installed them? Looks like you didn't have enough lube on there when you first put them in. Also for all new camshafts you should break them in gingerly for a bit to ensure something like you're experiencing doesn't happen. I vote installer error sorry.
Old Jun 1, 2004 | 08:54 AM
GZERO's Avatar
Default Re: Oh ****!! Why my cams look like this!!!??????? (RedlinedVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Did you use alot of lube when you installed them? Looks like you didn't have enough lube on there when you first put them in. Also for all new camshafts you should break them in gingerly for a bit to ensure something like you're experiencing doesn't happen. I vote installer error sorry.</TD></TR></TABLE>
i kinda agree with him.
but i've seen worst and they run ok, don't worry too much, off course, that is if
the lobes are smooth
Old Jun 1, 2004 | 11:23 PM
integraver's Avatar
Default Re: Oh ****!! Why my cams look like this!!!??????? (GZERO)
same thing happened to my pals car.. what we found out is that the initial lube was NOT enough.. i would say installer error too.. but like someone else said.. i dont think thats much of a problem as it seems like a slight rub.. good cluk
Gsrsi
Dec 1, 2011 07:36 PM
BDogggUT34
May 20, 2011 07:34 AM
turbodelsolb16a2
12
Nov 30, 2010 12:17 PM
slambedcivic
20
Oct 26, 2008 06:09 PM
ham
74
May 19, 2004 10:34 AM
