help! bent valves?
Old May 29, 2004 | 07:21 PM
1.7na's Avatar
Default help! bent valves?
Hi guys,
I started my car today and heard what sounded like valves hitting the piston.
The car was still running but barely idle. I shut down the car and open up the valve cover and looks like the cam gear slipped. I tried to manually crank the crankshaft but couldn't get it to move to tdc. I also notice that the engine shifts when trying to spin the crankshaft manually. I'm sure valves are bent but can it be worst since I couldn't spin the crankshaft? I didn't want to start the car since I couldn't spin the crankshaft and readjust everything to TDC. Please help...
thanks
1.7na
Old May 31, 2004 | 06:49 PM
1.7na's Avatar
Default Re: help! bent valves? (1.7na) update
Hi guys,
It maybe worst than I thought. The head is off and I don't see any piston damage. The valves are all in one piece but can't tell if it's bent. Now the bad news. I still can't spin the crankshaft manually back to TDC. I can manage to get 1 and 4 about half way up but it won't move any further. Does this sound maybe a bent connecting rod(s) or can it be worst and maybe a damage crankshaft? Man, this sucks! I pretty upset about this... I appericate any advise.
thanks
1.7na
Old May 31, 2004 | 07:05 PM
black2001ITR's Avatar
is the head on or off when trying to turn the crank???
Old May 31, 2004 | 07:12 PM
1.7na's Avatar
Default Re: (black2001ITR)
black2001ITR
Thanks. The head was off when I tried to spin the crank.
1.7na
jglatfelter7
Jul 12, 2009 05:42 PM
Bad Teggy
Nov 1, 2005 05:33 PM
crxfreak88
Mar 10, 2005 07:26 AM
polishprinze
Jan 31, 2005 12:21 PM
ModenaTwinTurbo
Nov 3, 2004 10:31 PM
