HELP! Big Problem here..
Old Jun 2, 2004 | 03:36 PM
UnspokenTruth's Avatar
Default HELP! Big Problem here..
Okay here goes, I have a 1987 Honda CRX SI that is giving me trouble. When you cut the switch on and take a tester to test the wires going to the fuel injectors they light up, everything is fine, when the car is running the #1 fuel injector won't light up, its not working, power isn't getting to it to shoot the fuel. When its running you also can take the wire off the other 3 injectors and it will bog down real bad, when you take the wire off the # 1 injector it doesn't effect the idle at all. My guess is the ECU isn't completely working anymore. If that doesn't fix it has to be the wiring harness. Is there a fuse that I can take out that will reset my ECU? If there is where is it located? Please help!
Old Jun 2, 2004 | 04:23 PM
b16supertuner's Avatar
Default Re: HELP! Big Problem here.. (UnspokenTruth)
i toasted an ECU once and my injector driver failed. how about just swapping over a different ECU?
Old Jun 2, 2004 | 04:48 PM
Chris22215's Avatar
Default Re: HELP! Big Problem here.. (b16supertuner)
bump for my boy.
Someone help him with his problem so he can sell the car and buy a swap for his 91 crx.
Chris
Old Jun 2, 2004 | 10:32 PM
One question was all the injectors not working? Or just a chosen view? When the ECU was toasted..
Old Jun 2, 2004 | 10:51 PM
civickiller's Avatar
you could do a continuity test between the injector and the ecu and see if theres a break anywhere. i would switch with a known good ecu first
Old Jun 2, 2004 | 11:12 PM
Default Re: HELP! Big Problem here.. (civickiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">you could do a continuity test between the injector and the ecu and see if theres a break anywhere. i would switch with a known good ecu first</TD></TR></TABLE>
I think thats what I'm going to do, I hope it will work if it doesn't.. I think it possibly could be my wiring harness, I'm REALLY hoping its not...
Old Jun 8, 2004 | 09:16 PM
Should I bump? Maybe more oppinions.
salemned
Sep 7, 2017 12:13 PM
Phoodles
Sep 21, 2013 11:05 AM
wburke69
Aug 9, 2010 09:19 AM
forlornvanity
Engine Management and Tuning
Jun 2, 2010 04:24 AM
CrX1988Zc
Aug 19, 2002 02:40 PM
