Can a leaky booster cause high NOx?
Old Jun 2, 2004 | 12:51 PM
4crx4me's Avatar
Default Can a leaky booster cause high NOx?
I was just reading on the web that one of the many causes of high NOx levels are vacuum leaks. Would a leaky brake booster be considerd a "vacuum leak"?
Any other ideas on High NOx levels but other emission levels are really low.
Old Jun 2, 2004 | 02:37 PM
Ekasey's Avatar
Default Re: Can a leaky booster cause high NOx? (4crx4me)
yes a vacuum leak can casue high nox becasue it's unmeterd air and unmetred air will make a car run lean. nox is created by excessive pressure and combustion temps in excess of 2500 degrees, casue by lean conditions.
Yes, a leaky booster can be considred a vacuum leak
Old Jun 2, 2004 | 02:49 PM
4crx4me's Avatar
Default Re: Can a leaky booster cause high NOx? (eLusive ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eLusive ek4 &raquo;</TD></TR><TR><TD CLASS="quote">yes a vacuum leak can casue high nox becasue it's unmeterd air and unmetred air will make a car run lean. nox is created by excessive pressure and combustion temps in excess of 2500 degrees, casue by lean conditions.
Yes, a leaky booster can be considred a vacuum leak</TD></TR></TABLE>
Thanks. Unfortunately, that's what I thought.
Honda4life777
Mar 29, 2010 07:06 AM
4DRmafia
Feb 26, 2007 07:45 PM
Quickgti1.8t
Apr 1, 2006 06:18 PM
aut0tek
Jan 4, 2005 10:28 PM
