water temp issues... help...
Old Jun 1, 2004 | 05:17 AM
pgpunkguy's Avatar
Default water temp issues... help...
i have my stock 5th gen civic cx engine in and i have an autometer water temp gauge hooked up.
before, i would normally run temps of around 165 degrees.
lately my car will get a lot warmer, reaching temps of as high as 240 degrees.
upon inspection, i notice that coolant is overflowing into the overflow tank but doesn't seem to be returning back to the radiator as it should.
i replaced the radiator cap and things "seemed" to return to normal for a little while. now it's running warm again and the coolant still isn't returning to the radiator.
i checked the hose between the radiator cap and overflow tank and there doesn't seem to be any leaks. i also checked the hose inside the overflow tank and there doesn't seem to be any leaks there either.
some help?... i doubt it's a bad thermostat because i don't think that would explain why coolant isn't returning to the radiator from the catch can. and for that matter, i doubt it's the water pump. is there some way of testing the radiator cap? perhaps i need new one again...
Old Jun 1, 2004 | 07:14 AM
pgpunkguy's Avatar
Default Re: water temp issues... help... (pgpunkguy)
btw, the stock water temp gauge doesn't go to "hot" but it did rise to exactly halfway and slightly above halfway. i know that the engine normally runs about 2/5ths of the way up from cold to hot. (less than half)
any help???
Old Jun 1, 2004 | 08:05 PM
LSVTEC 91 Civic's Avatar
Banned
Temp should be around 195-210, Does your car heat up when you're sitting in traffic, or when your're moving? Is your fan operational?
Old Jun 1, 2004 | 10:01 PM
pgpunkguy's Avatar
Default Re: water temp issues... help... (LSVTEC 91 Civic)
fan runs ok...
the car runs hot when i drive long on highway (coolant flows to radiator)
but when car cools down, fluid doesn't return to the radiator...
it's possible i have a pinhole leak in my radiator to overflow tank hoses...
i'm gonna check w/ a vacuum gauge this weekend...
until then, i just have to refill the radiator from the overflow tank manually before any long highway trips...
Old Jun 12, 2004 | 05:24 PM
Neukin's Avatar
my engine runs at 240 too with a mugen thermo (opens sooner) its a crx b16 with a t3t4. any ideas or suggestions. thanks -Alex
its prob. just the way i have the radiator set. darn hasport mounts
Modified by toyosupr at 2:38 AM 6/14/2004
DevonsHonda
Dec 20, 2013 05:40 PM
moncherris_em1
Honda Civic (2001 - 2005)
Mar 28, 2011 05:37 AM
schumi
Jun 21, 2008 03:27 PM
MYKJDM
Jun 2, 2007 06:09 AM
dc4drewH
May 22, 2006 01:06 PM
