Dyno HELP!!
Old May 30, 2004 | 06:35 PM
crxsirvtec's Avatar
Default Dyno HELP!!
hey..
Here is my dyno sheet.. I want to know why i have a flat spot from 6000 to 7000 RPM..
one is before tuning and the other is after.. (only in the CHIP)
Here are my Mods if it helps
B16A
Short Ram AIR
70 mm BBK TB
Skunk2 Intake Manifold
Crower Stage 2 A cams (springs and Ti retainers)
.030" off the head (around 11.1:1 CR)
ANR Compact Header
2.5 " Exhaust With a little High Flow CAT
DH-Racing Pulley (6 oz)
AEM Alt Pulley
9.5 LB Flywheel
Quiafe LSD
MSD Ignition
NGK #9 Plugs
What do you think would cause that dip??
Old May 30, 2004 | 06:46 PM
Muckman's Avatar
Moderator in Chief
Default Re: Dyno HELP!! (crxsirvtec)
Whats it tuned with?
Whats the AFR in that region?
Whats the timing in that region?
Old May 30, 2004 | 08:08 PM
b18cx's Avatar
Default Re: Dyno HELP!! (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Whats it tuned with?
Whats the timing in that region?</TD></TR></TABLE>
Old May 31, 2004 | 06:21 AM
crxsirvtec's Avatar
the AIR/Fuel is pretty close to be the same about 13 to 13.5 from 5000 to 9000
timming is stock on the dizzy.. and advanced about 10 degrees in the ECU from 5600 to 9000 (the same)
the line that it is very close to is 13:1
Old May 31, 2004 | 09:51 AM
crxsirvtec's Avatar
anything??
Old May 31, 2004 | 10:40 AM
user 996328629's Avatar
Cam timing?
My car flatlined from 5500+ To redline, because my cam timing is off..
Old May 31, 2004 | 12:52 PM
crxsirvtec's Avatar
Default Re: Dyno HELP!! (Swags04)
what do you mean by cam timing??
the cam gears??
or ignition??
Old May 31, 2004 | 01:25 PM
gears
Old May 31, 2004 | 01:33 PM
crxsirvtec's Avatar
i have the intake at +2 and the exhaust at 0
i did a dyno last year. and it didn't have that flat spot...
i changed to obd-1 from obd-0
went from a jun stlye header to the ANR Compact header
from the stock flywheel to a 9.5 lb
added a quiafe
from that didn't change much..
Old May 31, 2004 | 03:10 PM
Muckman's Avatar
Moderator in Chief
10 degrees? holy **** thats alot.
Old Jun 1, 2004 | 05:00 AM
crxsirvtec's Avatar
up
Old Jun 1, 2004 | 06:58 AM
dfoxengr's Avatar
i would take out that ad in your sig if you cant get your own motor to be tuned properly, lol. other than that try a different map in that area.
Old Jun 1, 2004 | 07:46 AM
crxsirvtec's Avatar
Default Re: Dyno HELP!! (hybridvteceg)
the maps are fine...
i ran 25 pulls with diffrent maps, all had the same line from 6000 to 7000
i'm sure it has to be something to do with the hardware..
Also it looks like no one knows here on honda-tech..
Old Jun 1, 2004 | 08:05 AM
Used2beAb16's Avatar
its the cams. those are the crowers with the stock primaries. Ive seeen another b16 with that problems and those cams. The reg 402's dont seem to have that dip.
Old Jun 1, 2004 | 08:19 AM
crxsirvtec's Avatar
Default Re: Dyno HELP!! (Used2beAb16)
last year, same cams, no DIP!!
here is last years..
Modified by crxsirvtec at 12:35 PM 6/1/2004
Old Jun 1, 2004 | 08:22 AM
to get rid of that dip on the b16 i was referring to, the tuner had to raise the vtec engagement to almost 7,000 rpms! Not good
Old Jun 1, 2004 | 05:00 PM
JDogg's Avatar
my first guess would be ignition timing... second cam timing... you have the head milled... did you compensate for the milling w/the cam gears?
Old Jun 1, 2004 | 06:44 PM
MajorPayne's Avatar
yes it has to be timing, if you look on the old dyno sheet and the new one, it looks like the flat line on the new one and hump on the old one are in pretty much the same spot, so depending on the timing it could do one or the other, youll just have to find if its the cams or distributor, but my money is with the cams
Old Jun 5, 2004 | 07:52 AM
crxsirvtec's Avatar
if i set vtec at 6700, would that work good??
eg6 type-R
38
Jan 5, 2012 11:10 PM
kdt3
Jul 25, 2006 06:28 PM
4DooRGiSzer
14
Oct 3, 2003 06:36 AM
egb20
24
Sep 23, 2003 01:25 AM
crxsirvtec
Jul 20, 2003 10:03 AM
