HELP!! Bent Valves?
Ok here's the deal. I have a Ls/vtec with GSR head and PR3 pistons. I advaced the timing and i drove the car started hearing a little tapping then after a while the car started misfiring, so i checked the #2 cylinder and noticed that the spark plug was messed up. The spark plug was missing some of the tip where it sparks and some of the porcelin. So i changed all the spark plugs and adjust timing to stock and my car still sounds like its misfiring. Do you think that the peice of spark plug could of bent my valves??
Compression testing tomorrow
I did a compression test on my motor and got:
#4cyl #3cyl #2cyl #1cyl
150psi 270psi 270psi 270psi
Should i do a leak down test? I did a piston ring test so i know its not the rings.
I tested the piston rings by pouring a little bit of the oil in the cylinders and then did a compression test. The compression did not go up in the cylinder that was the lowest leaving me the head with the problem.
I will be taking the head off next week.
jdmadam
24
Apr 18, 2012 10:49 AM
