Failed smog...some help please....
Old Jun 1, 2004 | 02:46 PM
FBP Si 2000's Avatar
Default Failed smog...some help please....
Well, I failed earlier today and it says "Gross Polluter". I suppose that goes on the car's records? They passed the ECU checkup stuff and visuals, but it failed the sniffer.
2000 Civic Si
Mods:
Greddy Turbo Kit
440cc injectors
Hondata 3b with p28 ECU
Custom exhaust setup with Carsound Cat...
Car has been tuned...
Here are the results.
15 mph: 2085 RPM
HC (PPM): MEAS: 167 (Max: 64) Failed
CO (%): MEAS: 0.87 (Max: 0.55) Failed
NO (PPM): MEAS: 2195 (Max: 477) Failed
25 mph: 2371 RPM
HC (PPM): MEAS: 73 (Max: 47) Failed
CO (%): MEAS: 0.17 (Max: 0.54) Passed
NO (PPM): MEAS: 659 (Max: 764) Passed
The car was warmed up, then it sat for about 25-30 minutes since there were other people there.
Now I have searched and read that I should have the CAT warmed good before the testing and keep the car running while I'm waiting in line...
Any ideas what I can do to make it pass besides puttting everything back to stock?
Thanks...I hope I can figure this out.
Old Jun 1, 2004 | 04:38 PM
david90's Avatar
it could be your Hondata 3b with p28 ECU. Those thing reprogram your fuel and emission to get HP and increase smog in exchange. Try disabling it.
Old Jun 1, 2004 | 07:58 PM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (david90)
When I used to run my camaro through emissions, I'd add a few liters of Denatured Alcohol in 1/2 tank of gas, or you can just run methanol, burns very clean. Passed with flying colors on the second trip.
Which state are you in?
Old Jun 1, 2004 | 08:27 PM
Default Re: (LSVTEC 91 Civic)
California...
The worst place to be in with a modified car.
Old Jun 1, 2004 | 10:17 PM
Ekasey's Avatar
Default Re: (FBP Si 2000)
hahah i gotta GO SEE BAR ok well anyways try your stock ecu and like you said make sure your cat is heated up
madking411
Apr 29, 2011 08:33 PM
krskrypto23
Aug 12, 2005 01:48 PM
FBP Si 2000
10
Jun 2, 2004 02:58 PM
HENRY
20
Sep 30, 2003 06:43 PM
hybrider
Apr 30, 2003 12:44 PM
