Car overheating. Oil pump?
Old May 29, 2004 | 08:11 PM
PHiZ's Avatar
Default Car overheating. Oil pump?
I inherited an engine that a kid had to get rid of because it was overheating.
I pulled off the head to check if it was a headgasket, and one of the pistons has spun a bearing at the small end. That pistons was sunken more than it should be.
Pulled apart the lower end, and the oil pump will NOT spin by hand. I have another oil pump off a defunct block that spins quite easily.
Would a motor run, without an oil pump? And just exhibit overheating problems?? Or would it not run at all?
-PHiZ
Old Jun 3, 2004 | 09:17 AM
PHiZ's Avatar
Default Re: Car overheating. Oil pump? (PHiZ)
-PHiZ
Old Jun 3, 2004 | 03:17 PM
Ekasey's Avatar
it wouldn run till evryhting siezed, oil pumps can be fdiffcult at tiems to turn by ahnd open it up and see what is going on
BlUAc
Aug 6, 2007 09:04 PM
