torque reading with long extension
Old May 31, 2004 | 09:30 PM
743power's Avatar
Default torque reading with long extension
Is there a formula for determining the change in torque reading when using an extension on a torque wrench? Some things need to be torqued properly, but are impossible to reach without an extension, like the oil squirters in a block. If I use a 4-6" extension, how much higher should I set the torque?
Old May 31, 2004 | 09:54 PM
michael O's Avatar
Default Re: torque reading with long extension (x743x)
There is a formula for when you change the actual length of the torque wrench. However if you add an extension vertically to it the torque shouldn't change or at least it shouldn't change enough to matter.
Old May 31, 2004 | 11:07 PM
_BEN_'s Avatar
For low torque applications the torque wont be affected enough because there will not be enough twisting force to twist the extension.
If you do feel the extension twisting go bigger. It takes some juce (like 100+ftlbs)to noticabley twist or distort a 6" 1/2" drive extensions.
BIG T
Jul 3, 2015 10:30 AM
arren123
Jul 20, 2010 12:51 PM
smxcan
Jan 12, 2009 07:17 PM
