fcuking o2 sensor is pissing me off
Old May 7, 2003 | 02:32 PM
roc's Avatar
roc
Default ******* o2 sensor is pissing me off
i just swapped out o2 sensor with my friends gsr one.i keep getting the same ******* code cel 1,oxygen content.my wiring is correct,and my friends o2 is good.wat now.im running a stock auto p28 ecu.wat else can cause a cel 1.if any one knows about this please help.this is the only thing left before i hit the streets.
Old May 7, 2003 | 03:15 PM
Katman's Avatar
Default Re: ******* o2 sensor is pissing me off (roc)
you try resetting the ecu ?
Old May 7, 2003 | 03:51 PM
Fuster_Cluck's Avatar
Default Re: ******* o2 sensor is pissing me off (Katman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">you try resetting the ecu ?</TD></TR></TABLE>
What I am thinking. I had this same problem with Code 21. CEL was gone, but code still appeared during diagnostic. I reseted the ECU and it was good as gold
Old May 7, 2003 | 06:42 PM
roc's Avatar
roc
i disconnected the battery,removed ecu fuse and back up fuse from the fuse box under the hood for about 30 sec.is that how you reset the ecu.please help
Old May 7, 2003 | 06:53 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (roc)
If you have the two 02s switched it will cause that problem.
Blaze
Vomit
Nov 20, 2013 08:24 PM
draxxus07
Sep 29, 2005 11:35 AM
t . b o z
May 1, 2005 11:40 PM
hondaguyexsi
Jan 10, 2005 12:53 PM
lawlerlaw
12
Feb 29, 2004 08:02 AM
