blowbye and what i can do?????
Old May 6, 2003 | 01:55 PM
svtec's Avatar
L D E S
Default blowbye and what i can do?????
basically here is the deal:
95 b18c
70k.
driven hard since 20k when i purchased it 3 years ago.
all synthetics since then as well. mobil 1 10w-30 and recently amsoil 10w-30.
basically it consumes like none other above 6000 rpm.
what should i do? i want to rebuild, but i was wanting to know the extensiveness of this rebuild. the motor still pulls hard and runs fine, but the blowby is obnoxious.
thanks for the help guys...
Old May 6, 2003 | 02:40 PM
altoid's Avatar
Default Re: blowbye and what i can do????? (svtec)
i have the same thing with my D series, it pulls hard but it burns a quart every fifty miles. compression is still 185 so its good i know that. I get a rattling like a ring is broken do you hear any other noise? i'd assume if its broken you probably need to get the block honed. But the rebuild wouldn't be hard at all either way
Old May 6, 2003 | 02:58 PM
svtec's Avatar
L D E S
Default Re: blowbye and what i can do????? (altoid)
no other noises. 1 quart per 50 miles! holly **** and i thought i was bad @ 1 quart per 2000 miles.
i dont hear anything else though.
Old May 6, 2003 | 03:04 PM
.RJ's Avatar
.RJ
If you rebuild it right, and break it in properly, it wont burn oil anymore.
Old May 6, 2003 | 03:33 PM
svtec's Avatar
L D E S
Default Re: blowbye and what i can do????? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">If you rebuild it right, and break it in properly, it wont burn oil anymore.</TD></TR></TABLE>
do you think that the helms and a good shopping list would be suffice with a sufficient amount of time for a noob at rebuilding an engine?
Old May 6, 2003 | 03:45 PM
.RJ's Avatar
.RJ
Yes but you should take the block/head/crank/rods/pistons to a machine shop for cleaning up and honing/decking/etc.
Old May 7, 2003 | 01:21 AM
3rdGteg's Avatar
have you checked ur pcv system if ur getting excessive blowby or did a compression and leakdown test to make sure a rebuild is even necessary?
4 door beast
Jul 29, 2009 08:29 PM
preludedriva
Honda S2000
48
Jan 10, 2008 12:03 PM
CyrusDrum
14
Apr 22, 2004 09:14 PM
Nextelbuddy
Feb 27, 2004 06:08 AM
93B17A
Apr 15, 2002 09:05 PM
