Lost motion device
Old May 7, 2003 | 09:19 PM
michael O's Avatar
Default Lost motion device
I was wonder if for higher revving do you need itr lost motion devices...
what impact do lost motion devices have on rev limits, maximal rpms? How do you identify itr vs non itr lost motion devices if they're needed?
Old May 7, 2003 | 09:48 PM
MikeSarr_GSR's Avatar
Default Re: Lost motion device (michaelOlson)
First and foremost, think of the LMA as shocks for your valvetrain. the springs do only so much, but the lost motion is what keeps them from bottoming out. think of it like pushing in a piano key, the lost motion device would be what returns the hammer back and returns the key. as far as needing them, well you could run the risk of bottoming them out with ghetto cam settings and even R cams. Chances are if you have stock installed heights, you will be ok for a while. Anything larger than ITR cams and you dont have the extra "degree" of travel at the valve which is critical at that measurement, you can begin to erode the effectiveness of these devices, especially combined with high lift/duration and elevated RPM. ITR LMAs also have more dampening/rebound pressure to them when compared to B16/18C1 units.
I dont know about you, I purchased a set. I have R LMAs and R valvesprings in my GSR head awaiting moderate cams they run about 28-35each and you need 8. R intake valvesprings are 150 inner and outer. Move the B16/B18C1 intakes to the exhaust side and you have true R upper valvetrain for $400. Skunk2 stage 1, TODA As, CTR/ITRs and cams of the like will be fine on this to about 8600rpm. I wouldnt rev higher unless I had something like a TODA springs/PE belt and ITR intake valves. Ti retainers are a waste, dont worry about them. Leave em stock to 9200. Jack at P1auto ran a strong setup he tells me with stock retainers on TODA Cs and Valvesprings to 9200rpm.
No one said re-engineering honda cars was cheap. All in all, you will have an extra bit of clearance at critical operating conditions than you previously would with stock units, therefore having an extra degree of saftey that you wouldnt have with the other units under the same conditions. I cat tell you how much because I dont know how to measure it. All I know is that guys like Roger Foo back in the day running R cams changed everything in his B16 and raced his EG to the ground.
What you are going to have to decide is, how much cam do I want? Then decide if you want to make the peace of mind investment.
Old May 8, 2003 | 04:44 PM
michael O's Avatar
wow thanks a lot for the info. I plan on running either itr cams or skunk2 stage2 cams depending on how much money I can scrounge up. Not sure about anything else but I'm still in the planning stages of my car so I only have the engine right now stripped down.
Old May 8, 2003 | 05:01 PM
Default Re: (michaelOlson)
definately do it with the stage2s... the ITRs... hmmm I still would. what motor are you doing this to... warning: stage 2s arent best for stock compression...
Old May 8, 2003 | 06:59 PM
michael O's Avatar
I'm doing this to a b16a. thinking about getting some ctr pistons. Can't remember what the compression is gonna be off the top of my head but I've got some calculations somewhere around here. I think it'll be around 11.4.1 or something like that
Old May 8, 2003 | 08:29 PM
inFamousOneSix's Avatar
theres a guy on ebay sellin some itr lma's for like 135 brand new in the box. I bought a set from him a couple weeks ago. great deal
I think he has a couple sets left
Old May 8, 2003 | 08:32 PM
Default Re: (inFamousOneSix)
TITE. wish I was on that deal... did you varify the part#...
Old May 8, 2003 | 09:39 PM
Default Re: (MikeSarr_GSR)
yep i checked the numbers, it was from an itr, also it had the blue dot on them
Old May 8, 2003 | 09:50 PM
blue dot owns
michael O's Avatar
Dang. Just checked Ebay, no1's selling them . Oh well i'm still in the early stages of this build and have plenty of time to wait
EK Dave
13
Jul 25, 2007 11:43 AM
1badda
Apr 28, 2006 06:25 PM
92b16vx
12
Sep 2, 2003 09:56 PM
dLo GSR-stolen-now-WRX
Nov 18, 2002 09:03 PM
cr00klyn718
Mar 17, 2002 02:39 PM
