Octane booster............??
Old May 5, 2003 | 08:04 PM
whatVTEC's Avatar
Default Octane booster............??
ok, right now i'm running a 75 shot direct port on pump gas (91 octane). i'm gonna up the jets to 100 shot and need to know what kinda gas to run. do i need to actually use race gas or can i use an octane booster on pump gas. and if i need race fuel does it have to be pure or can it be mixed with the pump gas?
Old May 5, 2003 | 09:37 PM
msilbernagel's Avatar
Default Re: Octane booster............?? (whatVTEC)
All too often you get answers like 'do a search first!", but, I actually read a cool article recently about using Xylene or Toluene as octane boosters -- complete with recipies and estimated octane.
I've also seen propane kits, since propane has a high octane also... so perhaps that is an option.
Both are worth investigating.
Luck,
Mark
Old May 5, 2003 | 09:48 PM
orange.honda's Avatar
Default Re: Octane booster............?? (msilbernagel)
on my friends kit we ran 103 octane from vp race fuels we just emptied out the pump gas with a siphon and then ran the car around the parking lot of the track until it died. then put in the new 103. and let me tell you that running a honda out of gas takes a while.
Old May 6, 2003 | 09:13 AM
whatVTEC's Avatar
Default Re: Octane booster............?? (orange.honda)
So using octane booster a bad idea?
Old May 6, 2003 | 09:48 AM
raene's Avatar
If you wanted to save time you could have just removed the gas tank drain plug bolt...heheheheh...
Old May 6, 2003 | 10:53 AM
Tweakmeister's Avatar
search for the article on this (google)
you should be fine mixing your own with Toluene or Xylene (better of the two).
as for the octane rating...listen for detonation and you'll know you need more.
Old May 6, 2003 | 11:07 AM
.RJ's Avatar
.RJ
Default Re: Octane booster............?? (Tweakmeister)
http://www.gnttype.org/techare....html
Old May 6, 2003 | 11:42 AM
dfoxengr's Avatar
Default Re: Octane booster............?? (.RJ)
thats a cool website
Old May 6, 2003 | 12:12 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Octane booster............?? (hybridvteceg)
whats your fuel management? You definetly need a fuel pump and injectors if you run that large of a shot.
Blaze
Old May 6, 2003 | 02:07 PM
whatVTEC's Avatar
Default Re: Octane booster............?? (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">whats your fuel management? You definetly need a fuel pump and injectors if you run that large of a shot.
Blaze</TD></TR></TABLE>
I have a walboro intank pump and aeromotive FPR. and i'm running stock injectors.
i have hondata s200 system but right now its running the stock LS program.
and its on a fully built B18b
Old May 6, 2003 | 02:18 PM
RyanEJ8's Avatar
He only needs stock injectors with a wet kit. You need bigger injectors with a 100 shot if you are running a dry kit like I am.
Old May 6, 2003 | 05:31 PM
whatVTEC's Avatar
Default Re: Octane booster............?? (RyanCivic2000)
yeah i'm running a wet kit
wrxrick
Sep 2, 2010 10:52 AM
boostincoupe
Dec 13, 2007 09:20 AM
Used2beAb16
39
Apr 8, 2005 06:09 PM
BlwnBlue
May 2, 2002 03:45 PM
Turbo00
Sep 7, 2001 01:12 AM
