OEM vtec pistons on LS rods
Old May 6, 2003 | 04:43 PM
Wazup's Avatar
Default OEM vtec pistons on LS rods
do stock LS rods need to be modified to fit oem vtec pistons on them?
Old May 6, 2003 | 05:01 PM
1_bad_EF's Avatar
Default Re: OEM vtec pistons on LS rods (Wazup)
you need to narrow the small end of the rod to use vtec pistons. its about .100" I think...dont try to do it yourself. I recommend getting the rods re-shotpeened after the narrowing procedure.
ps What pistons did you go with?
Old May 7, 2003 | 07:13 AM
untitled's Avatar
Default Re: OEM vtec pistons on LS rods (1_bad_EF)
um.............correct me if i am wrong but i am under the understanding that stock first gen pr3 b16a pistons will bolt up no problem and up the compression a bit.
Old May 7, 2003 | 07:28 AM
sander's Avatar
2.7(p/t)
Default Re: OEM vtec pistons on LS rods (88crx91integra)
you only need to machine the rods on R pistons, the b16 pistons press right on.
-sander
Old May 7, 2003 | 08:26 AM
drumking15's Avatar
Default Re: OEM vtec pistons on LS rods (jazzyfoo)
all pr3 pistons fit...p72 and p28's need to have the rod milled down some to fit like said above. I
lsvtec2000
Feb 6, 2009 07:08 AM
skoodles2k6
Sep 18, 2007 09:27 PM
justBLZE
Oct 15, 2004 04:11 PM
FastFoot
Sep 7, 2002 11:41 PM
Teg15
Apr 21, 2002 06:10 AM
