B16 swap then a CAS code I cant chase down
Old May 5, 2003 | 10:23 AM
WhiteDSM520's Avatar
Default B16 swap then a CAS code I cant chase down
I swapped a b16 into my CRX this weekend and started her up with an LS distributor and got a CAS code. Swapped the LS for the D16 dist and the code went away for about 30 miles and came back.
I can't seem to chase this down. I tried trading ECUs that didnt work. I'm out of ideas for now/ Anyone have some suggestions?
the car is a 91 CRX Si with a PWO ECU
Old May 5, 2003 | 10:24 AM
Spade's Avatar
Default Re: B16 swap then a CAS code I cant chase down (WhiteDSM520)
You need a B16 VTEC dizzy.
Different voltages.
Old May 5, 2003 | 12:14 PM
Default Re: B16 swap then a CAS code I cant chase down (Spade)
If that were the case why did the d16 dist work for so long before it threw the code?
Old May 5, 2003 | 01:04 PM
anyone?
Old May 5, 2003 | 05:31 PM
WhosThisGuy
Mar 1, 2014 06:15 AM
KDvtec5757
Aug 17, 2008 05:18 PM
TRhatchCRAP
Aug 1, 2003 05:40 PM
WhiteDSM520
May 6, 2003 11:06 PM
hybridbmw
May 20, 2002 04:02 PM
