ECU Problems! PLS HELP!
Old May 6, 2003 | 09:24 AM
DevilOnWheelz's Avatar
Default ECU Problems! PLS HELP!
I'm posting this for a friend...
He has a JDM Civic Vti Hatchback... 1999... (B16A2)
He recently bought a Skunk2 p28 ECU and the harness.... When he connected it to his car, V-Tec doesn't kick in, and the car runs like ****. He says he gets a check engine light "cel code 21" ... When he checks from his Apex-I Vafc there is no V-Tec signal....
And when the car is idling.. it goes up and down between 1500-2000 rpms for 5-10 times then it stops... and then if he gives it a little gas and lets go of the gas it does it again...
Any ideas what might cause the problem?
Is there any differences between the JDM Civics wiring harnesses and the USDM ones?
Thanks
Old May 6, 2003 | 09:54 AM
b17gsr's Avatar
error 21 = spool solenoid valve
If the P28 is running a B16 program (any way to check?), maybe the wiring harness is the problem.
Old May 7, 2003 | 03:00 PM
Bump...
Anyone?
Old May 7, 2003 | 03:03 PM
sgT's Avatar
sgT
Default Re: (DevilOnWheelz)
You sure its 21 and not 22?
Old May 8, 2003 | 06:47 PM
Default Re: (sgT)
yes its 21...
it works fine with the stock ecu... but not with the aftermarket one
phiberoptik
Engine Management and Tuning
Jul 11, 2010 08:56 PM
csmith21
Feb 27, 2010 05:34 PM
GuateskateVti
Aug 21, 2005 09:18 PM
GetawayInMoscow
Jul 17, 2005 02:03 AM
caspers_hatch
Apr 26, 2005 06:49 PM
