ls crank in a b16?
Old May 6, 2003 | 05:11 AM
wm5holla's Avatar
Default ls crank in a b16?
1-can you put a ls crank in a b16a2?
1- what will a ls crank do in a b16a2?, will it up the displacemtnt??
Old May 6, 2003 | 06:40 AM
Elex's Avatar
Default Re: ls crank in a b16? (wm5holla)
makes it a 1.8-2.0 depending on the bore of the block you need custom rods and pistons, im going thru http://www.hankthecrank.com for my B16 stroker kit cept im using the 87.2mm B18C crank instead of the 89mm LS crank hth.
Old May 6, 2003 | 07:33 AM
untitled's Avatar
Default Re: ls crank in a b16? (BSeriesMadness)
lets say i had a first gen b16. cant the ls rods and crank bolt up without hassle? i thought pr3 pistons boled to the ls rods no problem?
Old May 6, 2003 | 07:44 AM
Elex's Avatar
Default Re: ls crank in a b16? (88crx91integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">lets say i had a first gen b16. cant the ls rods and crank bolt up without hassle? i thought pr3 pistons boled to the ls rods no problem?</TD></TR></TABLE>
yea the rod journals are the same on the b16 and b18a/b but you have to remember the B16 is shorter then a B18 block so using LS rods would have the pistions sitting out the deck.
B16 rods are 134mm and i believe LS rods are 137mm
Old May 6, 2003 | 07:46 AM
untitled's Avatar
so a b18a crank will bolt up to b16a rods and pistons with no cleareance issues. just str8 bolt up. you dont have to machine the block or anything?
Old May 6, 2003 | 07:50 AM
Elex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">so a b18a crank will bolt up to b16a rods and pistons with no cleareance issues. just str8 bolt up. you dont have to machine the block or anything?</TD></TR></TABLE>
No you still need a piston with the wrist pin moved up for enough clearance.
im not sure on the mm i have them written down somewhere in my messy *** room.
Old May 6, 2003 | 09:27 AM
delslow94's Avatar
the deck height is taller on the b18 so to fix that you would have to get either a deck plate or custom rods to make it work...even if u do the custom rods the rod stroke ratio might be a problem.
Andrew-L
Dec 20, 2008 02:34 PM
CTR_B
Nov 9, 2008 05:54 PM
CTR_B
Oct 17, 2008 04:19 PM
CO_CReX
Apr 26, 2006 11:03 PM
GumballNA
Aug 5, 2004 02:49 PM
