yet another Skunk2 IM install
Old May 7, 2003 | 01:10 PM
oldskoolGSR's Avatar
Default yet another Skunk2 IM install
hey whats up everyone ive been reading up on skunk2 IM's lately and problems people have had with them because the other day i put mine on my B17 (pr3 head, same as B16) and i have all the vacuum hoses connected to something, cruise control as well but i am still having problems with idle.
when i start it up, the car idles very rough and after a couple seconds the CEL comes on and it bounces up to 4000 rpm for idle. i had to drive it home from my friends house like taht and it was leaking coolant all over the place so that means theres obviously a leak somewhere and i double checked everything making sure it was torqued down enough and yet this problem still persists..im thinking since i may have ran it very hot, i could have blown the head gasket but i dont know why it would still idle that high! im all out of ideas and im open to anything advice! thanks a lot!
Old May 7, 2003 | 01:55 PM
Spade's Avatar
Default Re: yet another Skunk2 IM install (oldskoolGSR)
What cell code u getting?
Old May 7, 2003 | 02:01 PM
machine4321's Avatar
if youe leaking coolant you might not have hooked up the heated throttle body...therer are 2 lines that run in to it with coolant in them.........but it doesnt explain the idel....sounds like a vac leak???
Old May 7, 2003 | 04:39 PM
im not exactly sure how to check what code it is throwing nonetheless, i ordered a new head gasket and new gaskets for my TB and IM, eventhough we got them off in one piece
Old May 7, 2003 | 04:47 PM
XiiiXiii's Avatar
Default Re: (oldskoolGSR)
http://www.londonautoclub.org/...s.htm
helped me when I was throwing CELs
-0ch0
Old May 7, 2003 | 06:55 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (XiiiXiii)
Is your MAP hooked up w/ out any leaks in the line? that can cause a crappy idle.
Blaze
Old May 7, 2003 | 07:26 PM
eRACING's Avatar
Default Re: (Blaze45)
did you get new gaskets when you replaced it? they eaisily tear when you take them off so you should look into that.
Old May 8, 2003 | 08:30 AM
D0HC's Avatar
Default Re: (erics99si)
There is a second (small) coolant hardline that is under the main one on the IM make sure that is capped or re-routed correctly.
Old May 8, 2003 | 08:32 AM
D0HC's Avatar
Default Re: (D0HC)
Also make sure your lines are running to your IACV correctly.
Old May 8, 2003 | 04:21 PM
Default Re: (D0HC)
yes i capped it off on the IM, but otherwise where would it be re-routed to? does the vacuum hose from the IACV go to the throttle body?
gray89si
Feb 13, 2008 07:17 PM
civicb16eg
26
Feb 9, 2006 10:47 PM
egCoupe
Aug 31, 2005 08:18 PM
Integra_Boi
May 31, 2002 09:25 AM
