Vehicle Speed Sensor?
Old May 7, 2003 | 02:13 PM
MidoriEK4's Avatar
Default Vehicle Speed Sensor?
did honda ever make like an analog VSS. meaning they didnt use a cable to the dash to read the speed? if so anyone have any info on this VSS like voltage rage for different speeds? im looking at making a digital dash readout like a SARD. so if anyone has any info please inform me. thanks.
DaN
Old May 9, 2003 | 12:59 PM
tpr's Avatar
tpr
Default Re: Vehicle Speed Sensor? (NA CRX Si)
No they use a 4 pluses per rev pluse generator. On the 4th gen its in the dash later years its on the top of the transmission.
Old May 10, 2003 | 11:25 AM
MidoriEK4's Avatar
Default Re: Vehicle Speed Sensor? (tpr)
so is there a way to make it cable-less?
Old May 10, 2003 | 02:35 PM
omahaturbocivic's Avatar
92 and newer civics do not have cables, they use an electronic vss right on the tranny. Im pretty sure it bolts right up to the older tranny as well, you just remove the part that the cable connects to and put the electronic one in its place. Thats what people putting the sir clusters into 4th gen civics must do so do a search for installing an sir cluster.
Old May 10, 2003 | 02:37 PM
I have a vss on off a 94 civic dx tranny if you want to make me an offer.
Old May 10, 2003 | 02:38 PM
MidoriEK4's Avatar
Default Re: Vehicle Speed Sensor? (omahaturbocivic)
hmmmm. well how much do they go for?
Old May 10, 2003 | 02:40 PM
MidoriEK4's Avatar
will i throw a code on my car if i switch from cable to electronic?
Old May 10, 2003 | 02:59 PM
nope just make sure that the signal off the vss goes to the ecu as well one way or another, on your car it would normally get that signal from the gauge cluster.
Old May 10, 2003 | 06:00 PM
Cory man's Avatar
I just converted over from cable to electronic. Easy conversion. Like they said above make sure you have one wire hooked up to the ecu wire near the cluster otherwise you will get a CEL. I used a 93 civic dx VSS. I have 2 others laying around if you want one. Oncesir@aol.com if you are interested.
wesleywhite989
Aug 22, 2008 01:07 PM
TMC_EF
Jul 16, 2007 10:37 PM
Krakkles
Oct 16, 2004 02:14 PM
t . b o z
Apr 11, 2004 01:26 PM
rice4life
May 14, 2002 07:24 PM
