HELP transmission problem
Old May 6, 2003 | 06:14 AM
TDGKORN's Avatar
New User
Default HELP transmission problem
I got in my car this morning and started it, the car was still in gear and the e-brake was on. My foot slipped off the clutch pedal and there was a loud clunck. Now the car will not move and is making a spinning noise from the drive's side of the engine bay.
The car is a 97 civic dx. I didn't have a chance to look at it this morning (already late for work) so any suggestions are helpful.
Old May 6, 2003 | 06:59 AM
untitled's Avatar
Default Re: HELP transmission problem (TDGKORN)
axles.
Old May 6, 2003 | 08:18 AM
TDGKORN's Avatar
New User
The whole axle assembly or just the shaft. I need a little more info.
Old May 6, 2003 | 12:03 PM
JimBlake's Avatar
Default Re:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TDGKORN &raquo;</TD></TR><TR><TD CLASS="quote">... I need a little more info.</TD></TR></TABLE>
So do we. Take a look & tell us what's spinning & what's not. If you busted the guts out of the CV joint, then the axle would spin but the wheel wouldn't. If the axle itself broke (?) then it would be flailing around making hammering noises.
Either way, you probably need a new axle assembly.
Old May 6, 2003 | 12:36 PM
94CivicSi's Avatar
Default Re: Re: (JimBlake)
seems pretty unlikely that a non-VTEC D series motor would be an axle buster.
Sounds to me like something in the clutch assembly failed. If you popped a spring out the hub, it may be lodged between the disc and the pressure plate and preventing them from making contact. What kind of clutch is it? Stock?
Old May 6, 2003 | 12:55 PM
untitled's Avatar
Default Re: Re: (94CivicSi)
um................anything can break axles. i was follin around beating the hell out of a ford aspire once and the axels busted.
Old May 7, 2003 | 05:39 AM
94CivicSi's Avatar
Default Re: Re: (88crx91integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88crx91integra &raquo;</TD></TR><TR><TD CLASS="quote">um................anything can break axles. i was follin around beating the hell out of a ford aspire once and the axels busted.</TD></TR></TABLE>
I said it was unlikely, not impossible. Aren't Ford Asipe axels just old mop handles anyway?
Pagley
Jun 29, 2008 03:56 PM
wu tang
Dec 14, 2007 05:31 AM
sirhavok
Jun 17, 2007 02:12 PM
slow motion
17
Nov 19, 2004 01:15 PM
92civeg
Aug 24, 2004 08:55 PM
