Another A/C question
Old Jul 25, 2003 | 11:44 AM
Stewie's Avatar
Default Another A/C question
On my 93 Eagle Talon I have oil on one of the lines coming from the codenser. I don't think I have a loss of pressure (haven't checked) and my A/C works fine.
Does anyone know what this is?
This is one side of the condenser with the drier/ receiver and it looks fine:
This is the side with the problem. You can see the line that connects to the condenser has oil on it:
Old Jul 25, 2003 | 01:25 PM
JimBlake's Avatar
Default Re: Another A/C question (Mac8008)
What's that loop in front of your condender? PS fluid cooler? Looks like oil spilled on top of those, too. So it's dripping from somewhere up above all that stuff?
Old Jul 25, 2003 | 01:57 PM
Stewie's Avatar
Default Re: Another A/C question (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">What's that loop in front of your condender? PS fluid cooler? Looks like oil spilled on top of those, too. So it's dripping from somewhere up above all that stuff?
Ya, the loop is P/S fluid cooler. I think I have oil on there too becuase I was touching it trying to feel were the leak was coming from.
When I looked again, the connector isn't coming off the condenser. It just attaches to the other line that you can see behind the P/S fluid cooler.
The fluid looked very clear on my hand.
thanks for your help
Old Jul 25, 2003 | 05:30 PM
Yougod's Avatar
possibly polypropalene oil (PAG oil) or some kind of similar substance in the A/C system. if nothing is leaking up above it then that would definitely be considered an A/C leak.
Old Jul 26, 2003 | 06:01 AM
Stewie's Avatar
Default Re: Another A/C question (Yougod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yougod &raquo;</TD></TR><TR><TD CLASS="quote">possibly polypropalene oil (PAG oil) or some kind of similar substance in the A/C system. if nothing is leaking up above it then that would definitely be considered an A/C leak. </TD></TR></TABLE>
I wonder why I don't have a loss of pressure than.
Old Jul 26, 2003 | 08:03 AM
Yougod's Avatar
sorry.. didnt mean polypropalene but whatever oil that is that is used in A/C systems. you probably won't recognize a change in A/C temperature right away. Looks like it's just seeping through. but odds are that it's an A/C leak. In my experiences, that's what it looks like when it leaks.
Old Jul 26, 2003 | 12:12 PM
Stewie's Avatar
Thanks again. I'll probably do a pressure check soon. At least the leak looks like it's in an area that's easy to get to.
What do you think I'll have to do to repair it? Just get a new seal?
Old Jul 26, 2003 | 12:21 PM
Yougod's Avatar
Well if it's an A/C line then you'll probably have to drain the system. Then check to make sure it's not the line that's bad because it would suck if you just replace the o-ring only to find out later that the line is leaking. After you put everything back together then you'd have to recharge the A/C.
dumada9
Jul 5, 2008 11:46 AM
NinjaTech
May 21, 2005 11:06 PM
1.8
18
Jan 6, 2005 05:34 AM
Shaun
32
May 26, 2004 03:46 PM
jerky
Jun 23, 2003 11:00 AM
