high impedance injustors in ef.
Old Jul 27, 2003 | 08:07 AM
Neukin's Avatar
Default high impedance injectors in ef.
im sure this has been covered but i didnt see it in the search.
what do i have to do to run high impedance injectors in a 1990 civic, do i just remove the resistor box or what?
what are dsm injectors high or low?
Modified by toyosupr at 8:17 AM 8/7/2003
Old Jul 27, 2003 | 10:32 AM
hybrid_KJ's Avatar
Default Re: high impedance injustors in ef. (toyosupr)
DSM injectors are peak and hold 2.5ohm resistors that need the resistor box in place. If for whatever reason you want to run Saturated injectors and remove the injector resistor box simply repin the engine harness side plug into an obd1 power distribution plug.
Old Jul 27, 2003 | 10:51 AM
Neukin's Avatar
Default Re: high impedance injustors in ef. (hybrid_KJ)
so i can just use the dsm injectors and thats it, that resistor box is good for those two, didnt know if the dsm resistor box is a different resistance?
damn spell check isnt working!!!
Charlie Moua
Oct 7, 2010 07:36 PM
schock3
Aug 25, 2009 12:37 PM
G0TB00ST
19
Apr 13, 2007 03:30 PM
discrete
Oct 26, 2005 06:46 PM
sivik2nr
Jun 11, 2003 09:59 PM
