different tire pressures?
Old Jul 28, 2003 | 06:21 PM
SOHC_MShue's Avatar
Default different tire pressures?
just wondering what tire pressures you were running in your front and rear tires when on the street, drag strip, autoX?
Old Jul 28, 2003 | 06:39 PM
976's Avatar
976
New User
Default Re: different tire pressures? (SOHC_MShue)
I run drag 28 psi front, 30 rear.
For auto-x and race it all depends on the course. A set course like nascar where you only turn left four times is different, almost all drivers have the same psi. So it is kindof a hard question to answer.
Many of the Type R guys that run on the famous (I forget the name) race track in VA run a specific psi for each tire. Just FYI!
Old Jul 28, 2003 | 10:32 PM
SOHC_MShue's Avatar
Default Re: different tire pressures? (976)
damn specific psi's for each tire lol. I'm not going that extreme, but should i put a good bit more air in my tires if i am autoxing or on the street and not drag racing?
Old Jul 29, 2003 | 05:32 AM
PupaScoopa's Avatar
Yes, you should run higher PSI when racing for better response and less rollover at high lateral G's.
I run Azenis at 42/45 F/R in autox.
Old Jul 29, 2003 | 12:15 PM
SOHC_MShue's Avatar
Default Re: different tire pressures? (PupaScoopa)
thanx
LS/V-T
Jan 19, 2011 04:41 PM
12thstreetjunkman
Mar 10, 2004 07:38 PM
5thgencivic
Jun 15, 2003 03:09 AM
tubedriver
Dec 28, 2001 11:19 AM
itr501
Jun 18, 2001 10:04 PM
