instrumental lights dead
Old Jul 25, 2003 | 08:36 AM
yee SERIOUS's Avatar
Default instrumental lights dead
ok...since i reinstalled my deck, my instrumental lights are dead. from the lights on my cluster to the lights on my climate control. the only thing that lights up on my dash is my deck, ebrake light, gas light, trunk light, and my turn signals. i check my fuses and they're not blown. except that i was suppose to use a 7.5 fuse for my instrumental lights and i'm using a 10 cause i didn't have a spare 7.5. but it was working fine with that fuse until i unpluged my deck and put it back in. i'm wondering if anyone could know what's wrong? could the wrong fuse be causing it not to work? i didn't think it would since nothing was wrong before. i hope i didn't mess up anything real bad i tried resetting my ecu to see if it'd make any difference...but it didn't. lol. any help with this would be appreciated. i have a 99 civic ex coupe. i really need to get this fixed cause i can't see anything at night time! it's completely dark! thanks.
Old Jul 25, 2003 | 05:45 PM
Yougod's Avatar
Default Re: instrumental lights dead (LiTtOGPiMp)
make sure your dimmer switch isn't all the way down. if that's not the case then check EVERY fuse. it helps if you have a test light so you don't have to pull each one. if fuses are ok then you got to recheck all wiring and plugs to make sure they are all plugged in.
let me know what you get from there.
Old Jul 25, 2003 | 11:16 PM
thanks...i've checked the dimmer switch multiple times. i thought i'd be hella stupid to miss that...so i've checked it enough to know that's not it. i'll pull out every fuse out tomorrow to get a better look. hopefully that's it. i'm positive that everything is plugged in, so i'm hoping it's just another blown fuse.
Old Jul 26, 2003 | 04:03 PM
bump...this happened to anyone else before?
Old Jul 26, 2003 | 04:35 PM
Yougod's Avatar
Default Re: (LiTtOGPiMp)
what all did you do to your instrument cluster.. like why did you remove it. did you recheck your connections?
Old Jul 27, 2003 | 11:35 AM
i removed my cluster cause i had an si one in for a while. when i put back in my ex it blew the fuse somehow. and it was a 7.5 fuse. i replaced that fuse like 3 times with a 7.5 and it just kept blowing, so i decided to use a 20. lol that made everything work. and then just last week, my friend had me install his deck in his car, and it wasn't working. so we decided to try in my car, it didn't work in mine either. and so then i reinstalled my deck and everything. later that day, i was driving my car at night and nothing turned on, not even my radio. i found a blown fuse for my radio under my hood, a 7.5 fuse, and replaced it with another 7.5 fuse. the deck works now. the only thing i can't get to work now is my lights. dimmer is all the way up. all the fuses are ok. everything is plugged in cause it functions the way it's suppose to, except no lights.
i'm still lost.....
Old Jul 27, 2003 | 01:22 PM
RICE POLICE SIP's Avatar
does your dome light work?
Old Jul 28, 2003 | 09:20 AM
yes my dome light works. i've switched clusters and it's the same
Old Jul 29, 2003 | 10:18 AM
bump...someone has to be able to help me!!! could it be that one of my blubs is blown? where could i get blubs?
Old Aug 1, 2003 | 01:09 PM
the guy at shucks told me that i could have a bad dimmer switch? is that possible? cause it just went dead out of no where?
Old Aug 1, 2003 | 04:48 PM
Yougod's Avatar
borrow a dimmer switch from some1 and see if it works. or maybe u can try jumping it somehow.
88aeFC3S
Jan 3, 2010 11:38 AM
Capt. Jimbo McSubipants
May 21, 2009 09:15 AM
95silverteg
Sep 30, 2008 04:48 AM
808style
Aug 11, 2003 06:30 AM
Mr Boston
Aug 7, 2002 08:22 PM
