Power Lock Relay??????
Old Jul 24, 2003 | 10:46 PM
aaj23's Avatar
Default Power Lock Relay??????
I just put the motor back in my car from it not being in for a couple months....when I put a new battery in, it sparked and blew the main fuse for what ever reason. I replaced the fuse, but the power locks still don't work and I didn't see any others blown in either fuse box.....Does any one know where the relay for the power door locks is. I have the dash off right now, so I assume this would be a good a time as any to replace it, especially if it's otherwise hard to get to.....
Thanks,
Aj
Old Jul 24, 2003 | 10:53 PM
salbaje's Avatar
Default Re: Power Lock Relay?????? (aaj23)
i believe the relay is behind the door panel on driverside
Old Jul 24, 2003 | 10:58 PM
aaj23's Avatar
Default Re: Power Lock Relay?????? (salbaje)
I've been looking at the parts diagrams, and it seems the only relays that I can find are either in the fuse boxes, or just above the driver's side kick pannel, unfortunately, the website I found with all the parts diagrams don't have what each relay does, just what the part number is, and how much it costs.....
If any one actually knows for certain it would be kool...I don't mind taking off the door pannels, as it only takes a coule minutes, but I would rather take apart as little as I have to....I'd just like to find out for sure before I put my dash back on and make it hard to get at some of them....
Thanks,
Aj
Old Jul 24, 2003 | 11:26 PM
Stripped Honda's Avatar
99-0104
they are usually in the drivers door under the pannel just pull the pannel off and look what do you have to loose
virgineg6
Oct 23, 2011 06:58 AM
hawkeye96
May 19, 2010 06:42 PM
SKY350
Acura TSX
Jan 19, 2010 04:44 PM
d16efsedan
May 21, 2009 06:14 AM
slo95cx
Aug 7, 2004 08:47 AM
