Constant CEL, Can't check CEL's 2 diff ecu's??
Old Jul 27, 2003 | 03:12 PM
Jonathan_ED3's Avatar
Default Constant CEL, Can't check CEL's 2 diff ecu's??
What would cause this?
All fuses are good.
I've tried two different ECU's, and on both, I'm getting no VTEC, constant CEL, can't check codes, and the CEL does not go off after 2 seconds like it should.
I'm really lost here.
Would a bad relay or something cause this??? If so, how do I check and which ones should I check?
Old Jul 27, 2003 | 03:15 PM
skribblah's Avatar
Default Re: Constant CEL, Can't check CEL's 2 diff ecu's?? (Jonathan_EH)
you sure your shorting the right connector?
Old Jul 27, 2003 | 03:18 PM
Default Re: Constant CEL, Can't check CEL's 2 diff ecu's?? (skribblah)
Yes.
Even if I wasn't, the CEL should go off after 2 seconds when the key is 'on', but it doesn't.
I'm leaving Friday on a 2K mile road trip, and I'd really like to get it figured out by then!
Old Jul 27, 2003 | 07:23 PM
any ideas?
Old Jul 27, 2003 | 08:42 PM
skribblah's Avatar
does the actual bulb come on so as you can rule a blown bulb out?
Old Jul 28, 2003 | 04:03 AM
Yes, the bulb is on....just constantly, and won't flash to check codes or anything.
I'm still getting no VTEC, and it's running really rich.
Old Jul 28, 2003 | 04:48 AM
1bad-eg's Avatar
Have you tried checking the wiring to see if something is making contact somewhere it shouldn't?
Old Jul 28, 2003 | 05:17 AM
Default Re: Constant CEL, Can't check CEL's 2 diff ecu's?? (1bad-eg)
you mean in the actual wiring harness itself? I've checked it as best I can...I can't follow the entire thing....but like I said, it was working fine previously, and all my wiring was soldered/wrapped, so I don't think anything came loose.
Old Jul 28, 2003 | 05:22 AM
1bad-eg's Avatar
Then go ahead and check relays. Like pgm-fi, etc.
Old Jul 28, 2003 | 05:25 AM
I don't know how to go about checking relays.
What exactly do I need to do?
91ef_civic
Mar 22, 2011 02:33 PM
beeroh
Sep 24, 2004 08:16 AM
See Are X
Jul 13, 2003 09:26 PM
Jonathan_ED3
May 26, 2003 10:52 AM
NegativeLift
Aug 4, 2002 08:02 PM
