Need Help!!
Old Jul 28, 2003 | 08:36 PM
not133t's Avatar
Default Need Help!!
I just recently swapped a JDM B18C into my 99 GSR, I put the GSR alternator on the B18C along with the GSR AC also put the GSR engine harness on, all was fine for about a week. First off during the day the speedometer stopped working, then i was I95 going to Ft. Lauderdal for dinner when it seemed like the fuel cut at 4000rpm in 5th gear, so i decided to get off at the next exit and have a look, i stopped at a light and the car just died, wouldnt start. The battery was dead. I just tried putting the alternator that came with the motor back on and still isnt charging the battery. But with a charged battery it will run, until i remove the terminals which kills it right away.
NEED HELP!!!
Old Jul 28, 2003 | 10:34 PM
salbaje's Avatar
Default Re: Need Help!! (not133t)
alternator is bad
Old Jul 29, 2003 | 05:35 AM
JimBlake's Avatar
Default Re: Need Help!! (salbaje)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by salbaje &raquo;</TD></TR><TR><TD CLASS="quote">alternator is bad </TD></TR></TABLE>
Or not hooked up properly. Check ALL the wiring, including the main engine-to-chassis ground...
Old Jul 29, 2003 | 06:28 AM
not133t's Avatar
Default Re: Need Help!! (JimBlake)
then i must have 2 bad alternators?.... the GSR alternator was working for a week and then stopped.... dont get it?
Old Jul 29, 2003 | 08:22 AM
not133t's Avatar
bump
Old Jul 29, 2003 | 09:01 AM
kikicamacho's Avatar
Get your alternators tested. Autozone and Checkers both do it for free I believe.
Old Jul 29, 2003 | 04:12 PM
DJ_SaNdOz's Avatar
Default Re: Need Help!! (kikicamacho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kikicamacho &raquo;</TD></TR><TR><TD CLASS="quote">Get your alternators tested. Autozone and Checkers both do it for free I believe. </TD></TR></TABLE>
that is your best bet my man
Old Jul 30, 2003 | 03:30 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not133t &raquo;</TD></TR><TR><TD CLASS="quote">then i must have 2 bad alternators?... dont get it?</TD></TR></TABLE>
Sounds like quite a coincidence. I'd check the wiring again.
trianglegreg
Feb 4, 2007 05:48 PM
DJ Gurgla GSR
Dec 19, 2005 04:27 PM
ownedbyvtec
Aug 24, 2003 01:18 AM
mkhooaah
Jul 28, 2003 08:15 AM
Teal95Coupe
Jul 30, 2002 02:20 PM
