how many revs?
Old Jul 27, 2003 | 01:35 PM
b16a2EG6's Avatar
Modified by SiRbob at 10:56 PM 7/27/2003
Old Jul 27, 2003 | 01:50 PM
RCautoworks's Avatar
Default Re: how many revs? (SiRbob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiRbob &raquo;</TD></TR><TR><TD CLASS="quote">i would like to know how high a b16a2 can rev safely as i have chipped mine and the rev limiter is no longer there. i'm thinking 9000rpm but i'm not sure. i have a stock engine apart from DAC.</TD></TR></TABLE>
I would not bring it above 8,200 . There is no reason to go higher when your engines valve train is stock.
Old Jul 27, 2003 | 06:15 PM
SICKSOLSI's Avatar
Default Re: how many revs? (90blackcrx)
Honda made the 8200rpm rev limiter for a reason....dont go above it
Old Jul 27, 2003 | 06:43 PM
granada_sun's Avatar
word
Old Jul 27, 2003 | 06:48 PM
RSX_TypE-1's Avatar
i like to keep things below redline which is just as the tach barely taps into 8000 it provides the power you need and is a must for a healthier happier engine
Old Jul 27, 2003 | 07:06 PM
not bad for stock set up, with higher rpm mods (skunk manifold, 4-1 header, cams, etc) ie at the strip, shifting higher can improve times.
Old Jul 27, 2003 | 09:29 PM
Malgerus's Avatar
Default Re: (granada_sun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by granada_sun &raquo;</TD></TR><TR><TD CLASS="quote">not bad for stock set up, with higher rpm mods (skunk manifold, 4-1 header, cams, etc) ie at the strip, shifting higher can improve times.</TD></TR></TABLE>
With more risk of damaging an older engine....
Old Jul 27, 2003 | 10:58 PM
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
With more risk of damaging an older engine.... </TD></TR></TABLE>
true, but if taken care of, not to worry.
accord03coupe
Honda S2000
17
Mar 27, 2007 03:28 PM
DB1_559
Oct 17, 2005 06:00 AM
itr1244
Oct 1, 2005 11:37 PM
90dxhatch
93
Aug 5, 2005 01:58 PM
civicnar
Feb 18, 2004 07:14 PM
