oil control jet question
Old Jan 19, 2003 | 01:25 PM
d15dood's Avatar
Default oil control jet question
ive got a sohc non-vtec zc, 88-91. whats the worst that could happen if the oil control jet was removed from the block? would the oil pressure in the head be too high or too low? and the resuts of that would be....?
thanks alot.
Old Jan 19, 2003 | 01:47 PM
d15dood's Avatar
Default Re: oil control jet question (jungle)
no one?
Old Jan 19, 2003 | 04:20 PM
altoid's Avatar
hrmm....i believe the oil jet simply allows the fuel to go up there with a higher velocity so you'd end up with less oil and something would fuse with something else or wear away to nothing
Old Jan 19, 2003 | 04:34 PM
tinkerbell's Avatar
oil pressure would be way too low.
this is bad...
t..
Old Jan 20, 2003 | 10:35 AM
d15dood's Avatar
thanks
Old Jan 20, 2003 | 10:41 AM
gtpilot's Avatar
You can't remove it all togeher - you will end up with the majority of your oil in the head and nothing left for the bearings. In race applications we do take it out, drill it through with a 1/6" bit and reinstall it to get a little more oil flow to the top ogf the motor.
Kirk
NstyGrnHatch
May 30, 2009 06:28 AM
Tushner
Jun 3, 2004 09:20 AM
vtec.dc2
Feb 1, 2004 10:49 AM
charjacq
Aug 13, 2003 08:01 AM
