Moroso pan + Fram SureDrain?
Old Jan 20, 2003 | 02:56 PM
hatchy's Avatar
Default Moroso pan + Fram SureDrain?
Problem: I am afraid of striping the oil drain bolt on my Moroso pan (for my 1997 B18C1) .
Possible Solutuon: Replace the drain bolt with a Fram Sure Drain. Since the "bolt" won't need to be removed and re-installed after each oil change, it will reduce the chances of striping the bolt.
Qestion: Which Sure Drain kit do I need? Anyone know the pitch and diameter of the stock Moroso pan bolt (again, for a 1997 B18C1 motor)
Thanks
Old Jan 20, 2003 | 03:45 PM
BROOD's Avatar
Default Re: Moroso pan + Fram SureDrain? (hatchy)
My roommate tried that Sure Drain thing on his car.....after he finished the first oil change he said he could **** with more flow than his Sure Drain did. He shortly removed it and went back to stock. But I personally have not tried it on my car.
Just be gentle with your Moroso drain bolt.
Old Jan 20, 2003 | 04:44 PM
hatchy's Avatar
Default Re: Moroso pan + Fram SureDrain? (SLPR)
I am not concerned about the flow rate (I'll just let it sit and do the oil filter) but the Moroso pans are known to strip easily, and I am kinda goofy with tools and I know I may slip up some day and screw up my pan..
sleeperhonda
10
Aug 20, 2013 08:18 AM
ombl4
May 10, 2007 01:42 PM
Utilitarian
Mar 16, 2006 07:47 AM
MechEng
Oct 21, 2005 12:14 PM
AlxSiR7
Oct 5, 2004 03:44 PM
