Pistons poll!!!
Old Jan 20, 2003 | 12:44 AM
Cashflo's Avatar
Default Pistons poll!!!
Wheres the best place to buy pistons?What pistons should I get for all motor trim? Pistons are going into gsr.
Old Jan 20, 2003 | 01:04 AM
feelthebreak's Avatar
Default Re: Pistons poll!!! (eghead)
arias
Old Jan 20, 2003 | 07:00 AM
PhatOptimo's Avatar
Default Re: Pistons poll!!! (feelthebreak)
You forgot PCT (CTR). WHY? They are cheap and they are the best OEM piston for all motor. I am running them and them.
Old Jan 20, 2003 | 07:18 AM
qcoffey's Avatar
Default Re: Pistons poll!!! (Phat_Optimo)
I did some research a while back. I believe it was on the FF-Squad website they had multiple listings for what compression could be had by using stock pistons. With your B18C1 block with CTR pistons and a B16A head your compression would be in the area of 11.8:1. Why waste money on aftermarket? CTR pistons are half the cost of those other aftermarket ones. They also come with the special coating to reduce friction.
If this is the case and you combine this with some good cams and head work you'll be making some serious power. I would check out their website some real good info.
Old Jan 20, 2003 | 10:38 AM
advanracing62's Avatar
Default Re: Pistons poll!!! (qcoffey)
CTR, with a thin head gasket, will yeild some good compression... and is cost effective. so that's 3 votes for CTR
Old Jan 20, 2003 | 10:53 AM
altoid's Avatar
Default Re: Pistons poll!!! (advanracing62)
how much can you get ctrs from a usdm dealer, if at all?
Old Jan 20, 2003 | 10:59 AM
Kamin's Avatar
Default Re: Pistons poll!!! (altoid)
cant get them from a us dealer.
Old Jan 20, 2003 | 11:17 AM
qcoffey's Avatar
Default Re: Pistons poll!!! (Kamin)
You can buy CTR pistons new through several aftermarket companies. One that comes to mind is Options Auto Salon. I think they carry them for something like $60 bucks per piston. Also check the Best Buy section of this site.
Old Jan 20, 2003 | 11:24 AM
Rydaddy's Avatar
I picked some up off H-T not too long ago for $180 shipped (without rings). I have seen them online at stores for around $200 w/out rings.
Old Jan 20, 2003 | 12:27 PM
Cashflo's Avatar
Default Re: Pistons poll!!! (Rydaddy)
can ctr pistons be used for daily driving?
Old Jan 20, 2003 | 12:36 PM
PhatOptimo's Avatar
Yes, they are in my daily driver. You must run the highest octane available. I also reccomend arp rod bolts (9mm) especially if you going to turn it high (over 8,500 rpm).
Old Jan 20, 2003 | 12:40 PM
sgT's Avatar
sgT
Actually , its 12.25-12.5 CR
Old Jan 21, 2003 | 08:56 AM
all motor b20b's Avatar
arias
Old Jan 21, 2003 | 12:03 PM
tegrakid's Avatar
Default Re: Pistons poll!!! (all motor b20b)
would ctr pistons work in a LS motor what would be needed for this combo? my LS is on the verge of croaking (it starts knocking at 4000 rpm) so im gonna do a rebuild on the bottom end of my next motor with pistons rings and thinner head gasket any other recmmendations?
Old Jan 21, 2003 | 08:15 PM
NVMYSi's Avatar
Default Re: Pistons poll!!! (tegrakid)
CTR pistons
Old Jan 21, 2003 | 08:48 PM
McFly's Avatar
Default Re: Pistons poll!!! (NVMYSi)
check out this site and e-mail them for a price on the ctr pistons with rings.
http://www.alljdm.com
Old Jan 21, 2003 | 11:58 PM
Kelvin96GSR's Avatar
25 Year Member
Default Re: Pistons poll!!! (UnderFire)
CTR
Old Jan 22, 2003 | 01:44 AM
MikeSarr_GSR's Avatar
Default Re: Pistons poll!!! (Kelvin96GSR)
CT to the R pistons baby...
skata89
Apr 24, 2008 11:06 AM
lickety_britches
Mar 21, 2008 07:31 PM
Colt Seavers
33
Feb 22, 2006 04:17 PM
dc2gsr96
24
Feb 20, 2006 12:34 PM
1hotcivicSi
Feb 22, 2004 11:21 PM
