To rebuild or not to rebuild?
Old Jan 17, 2003 | 03:56 PM
Pharcyde's Avatar
Default To rebuild or not to rebuild?
Aight would you purchas a b17a GSR engine wiht 200 xxx KM on it for 700 wiht tranny and do a rebuild or would you just save up a buy a GSR wiht low k?
Is a rebuild going to give me a reliable engine that will last?
Old Jan 17, 2003 | 05:28 PM
turbo_civic's Avatar
Default Re: To rebuild or not to rebuild? (Pharcyde)
Good question, i'm buying a b18 from a 90 integra ls for $50 with over 400 000k, i'm definetly doing a rebuild specifically for a turbo setup.
Old Jan 17, 2003 | 06:15 PM
tominos's Avatar
i'd do the rebuild if you're not needing the engine quickly, b/c then when you rebuild you can rebuild it with aftermarket parts, ie. high comp. forged pistons and rods, etc.
Old Jan 17, 2003 | 07:54 PM
Cashflo's Avatar
Default Re: To rebuild or not to rebuild? (tominos)
just save for gsr and get type-r pistons for allmotor set up. Thats what everyone is doing now. Forget about the b20vtec hype. Gsr with type-r pistons kick ***. Seen a guy do 12.3 with 1600lbs 92 hb with non-lsd tranny, aftermarket cams retainers, clutch, and type-r pistons.
Paperboy177
Sep 14, 2010 05:11 PM
kte324
Mar 30, 2010 06:49 PM
itslogz
Feb 9, 2009 10:43 PM
GruvyTune
Dec 10, 2001 07:21 PM
gsr camel
Jul 23, 2001 09:15 PM
