Resizing Rods
Old Jan 20, 2003 | 03:14 PM
McFly's Avatar
Default Resizing Rods
I just got my ARP rod bolts in and the instructions say to have the rods resized. Is this really necessary? What size bearing would you use after resizing? Thanks
Old Jan 20, 2003 | 06:33 PM
non-VTEC's Avatar
Default Re: Resizing Rods (UnderFire)
have the machine shop measure the big end of the rod after the new rod bolts are pressed in. if the big end has changed or de-formed from the pressing of the new rod bolts then have the big end re-sized. if not then dont bother............just get the correct bearings.......
good luck
Old Jan 20, 2003 | 07:11 PM
McFly's Avatar
Default Re: Resizing Rods (non-VTEC)
Thanks
Old Jan 21, 2003 | 08:39 AM
martini's Avatar
I believe the problem is with the head of the bolt, it's too big for the space on the cap.
maybe I'm wrong.
Old Jan 21, 2003 | 10:04 AM
sgT's Avatar
sgT
Default Re: Resizing Rods (martini)
more times than not the big end will distort slightly.
its really a good idea to at least check to make sure its not distorted.
roycivic92
Sep 14, 2009 01:22 PM
one slow coupe
10
Feb 6, 2007 01:57 PM
fkncivic
Feb 15, 2005 07:24 AM
b2Ovtec
11
May 11, 2004 12:51 AM
untitled
Jul 2, 2003 11:25 PM
