how to remove the tps?
Old Jan 19, 2003 | 12:51 PM
intedgra's Avatar
Default how to remove the tps?
how do you remove the throttle position sensor off the throttle body? there are like two washers/rings holding down the tps but how do you take it off without breaking the sensor? thanks
Old Jan 19, 2003 | 01:11 PM
Dave P.'s Avatar
Default Re: how to remove the tps? (intedgra)
the 2 "washer rings" are probably rivets. you would have to drill them out. I don't know about other JDM motors but on my H22A it has bolts that hold my tps in. On my USDM SOHC 2.2L it was held in by rivets...
Old Jan 19, 2003 | 01:20 PM
ismkv8s's Avatar
Default Re: how to remove the tps? (Dave P.)
you have to use a grinder or dremel and put a straight line in it so you can fit a flat head screwdriver in it and unscrew it. that all.
Old Jan 19, 2003 | 01:34 PM
poo flinger
Guest
Posts: n/a
Use a dremel with the fiberglass cutter and break the seal on them. Then when you it back on, use some small bolts.
Evasion
Aug 20, 2010 05:37 PM
JuNkDoGAccOrD
Mar 5, 2008 04:51 AM
seelyd
Feb 5, 2007 10:01 AM
Singlecam4dr
May 22, 2006 06:58 PM
MugenB16A2
Mar 21, 2005 07:16 AM
