which motor?
Old Jan 19, 2003 | 08:26 PM
icelarry27's Avatar
Default which motor?
which motor should i get if i had $6,000...which includes the cost for everything, mounts, cost to drop it in....motor....everything?????
Old Jan 19, 2003 | 10:14 PM
ExospeedAMcrx's Avatar
Default Re: which motor? (GRCuadros)
you can do it way less than 6K. for about 5K, it'll include trans, ecu, mount kit, freshly done bottom end, gasket, belts, etc.
Old Jan 19, 2003 | 10:43 PM
texan's Avatar
Default Re: which motor? (exospeedAMcrx)
You can't intelligently vote on that poll until you know what your power and performance goals are for the setup. 6k can get you a B16A w/ Rev Hard 2c turbo kit, which would eat any of those alive assuming people were voting for NA setups. So what are you after, performance and setup wise?
Old Jan 19, 2003 | 10:45 PM
EK MONEY's Avatar
Default Re: which motor? (texan)
stock type R. great power and reliable..
Old Jan 20, 2003 | 12:31 AM
If You Slip You Die's Avatar
you should have close the poll
Old Jan 20, 2003 | 11:22 AM
icelarry27's Avatar
i was thinking an ls-vtec all motor engine, maybe making like...between 185-195 whp...dont wanna go turbo or supercharge....
Old Jan 20, 2003 | 03:17 PM
icelarry27's Avatar
anybody?
Old Jan 20, 2003 | 08:18 PM
feelthebreak's Avatar
i say SOHC.. because that`s what i`m doing right now.
Old Jan 21, 2003 | 03:11 AM
D16Z6racing's Avatar
Default Re: which motor? (feelthebreak)
D16Z6 full swap.........$800 (w/ install)
built for upto 12psi.....$3000 (labor, parts)
GReddy turbo kit.......$2025 (no i/c, ext temp gauge, fuel pres gauge/pod needed, install)
94+ GSR radiator......$150 (w/ welding install)
saved ya $25
[Modified by D16Z6racing, 4:13 AM 1/21/2003]
gnxpro24
18
Nov 12, 2014 03:43 PM
nvmeplz
135
Dec 29, 2006 03:20 PM
415Hatch
11
Jan 22, 2005 09:57 PM
busychild
Jun 15, 2004 07:37 AM
Nader_D
Jan 28, 2004 09:20 AM
