5 wire to 4 wire O2?
Old Jan 20, 2003 | 11:15 AM
sherman's Avatar
Default 5 wire to 4 wire O2?
I need to convert my 92 vx that has a 5 wire o2 into a 4 wire. I have a 4 wire with the plug and i was told that i can use 4 of the wires from the 5 wire to wire up the 4 wire. Does this make sense?? What wires do i use?? 5 wire has black, red, orange, yellow, and white wires. The 4 wire has 2 blacks, green and white. Is this going to work?? Thanks for the help.
Old Jan 20, 2003 | 03:27 PM
sherman's Avatar
Default Re: 5 wire to 4 wire O2? (sherman)
Anyone??
Old Jan 20, 2003 | 05:42 PM
Cashflo's Avatar
^bump^ I would also like to know this also.
Old Jan 20, 2003 | 06:34 PM
hondaeg5's Avatar
Default Re: 5 wire to 4 wire O2? (eghead)
i had this problem as well. just run the 4 wires from the o2 directly to the ecu. this is the eaiest way. if you need the pin locations i can get them for you. pm me.
Old Mar 17, 2003 | 06:04 PM
dwnthehatch's Avatar
Default Re: 5 wire to 4 wire O2? (hondaeg5)
Bump ^
Did you ever figure it out?
Combustion Contraption
May 30, 2011 10:50 AM
slammedz6ef
Feb 15, 2008 07:46 AM
hksdrager
May 11, 2007 07:55 PM
nsxmatt
Aug 7, 2002 07:20 PM
