building block on budget
Old Jan 18, 2003 | 11:58 PM
JDMCIV95's Avatar
Default building block on budget
i recently put skunk2 cams ,springs, retainers,and intake manifold on my b16. im wanting to do something to the block. what is the best, less exepensive high compression piston and titanium rods to use?
Old Jan 19, 2003 | 12:41 AM
Quik Chris's Avatar
Default Re: building block on budget (JDMCIV95)
hehe, you say titanium rods and inexpensive so casually. I'd say the best piston for your application is the PCT piston (Civic Type R B16B). They're ~$300, and will raise your compression (somebody help, the CR calculator is broken again!)
You'll be fine N/A w/ stock rods.
Old Jan 19, 2003 | 07:54 AM
VTEC-DA's Avatar
Default Re: building block on budget (Midori Shinkansen)
CTR pistons and a 2-layer headgasket will yield you just aoubt a 11.1:1 compression, which is much better than the stock compression on the B16. And while its apart, since your on a budget, have the stock B16 rods shotpeened, for a little more strength.
cameron_bailey
Mar 15, 2013 05:54 AM
Bleez
Nov 15, 2011 06:35 PM
tgreaves
Dec 22, 2005 05:53 AM
hOndafienD 04
Feb 10, 2005 04:00 AM
