Cam install. Assembly lube?
Old Jan 17, 2003 | 09:38 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Cam install. Assembly lube?
Is this the same as any high temperature grease? I'm talking about what I need to lube the cam journals with. Also is Honda bond the same as lock tight?
Old Jan 17, 2003 | 09:54 AM
Tstorm's Avatar
Default Re: Cam install. Assembly lube? (ActiveAero)
Honda bond is not the same as Lock Tight. Honda bond is gasket sealer and lock tight is used to secure nuts and bolts together like glue for metal, it comes in 3 main strengths blue, green and red.
Old Jan 17, 2003 | 11:24 AM
brinks's Avatar
Dont use honda bond on the cams! Thats not what its for. Give crower a call and tell them you bought some cams, and lost the lube, and you need to know what you can buy local.
sparkz's Avatar
Yes use assembly lube when installing cams, cam journals or anything rotating mass. Honda bond is not the same as lock tite, but a gasket sealer.
Old Jan 17, 2003 | 01:51 PM
tnbigdawg's Avatar
Default Re: Cam install. Assembly lube? (sparkz)
assembly lube is not the same as high temp grease!!!!!
Assembly lube breaks down and blends in with the motor oil once the oil gets running in your engine..
USE ASSEMBLY LUBE!!!
Old Jan 17, 2003 | 02:26 PM
altoid's Avatar
Default Re: Cam install. Assembly lube? (tnbigdawg)
i dunno how it is with brand spankin' new cams, but i just recently swapped cams, i just lubed it up with the oil that was in the head. it worked quite well...maybe it only matters when you've got a dry motor and you're building it before you put it in?
Old Jan 17, 2003 | 04:32 PM
Atomic 1320's Avatar
Default Re: Cam install. Assembly lube? (altoid)
Use cam lube on the lobs. Use regular motor oil on the journals.
Old Jan 17, 2003 | 05:35 PM
GreenD's Avatar
Default Re: Cam install. Assembly lube? (Atomic 1320)
i use this stuff:
Old Jan 17, 2003 | 06:06 PM
polymath's Avatar
Default Re: Cam install. Assembly lube? (GreenDestiny)
I've always used lithium grease...
Old Jan 17, 2003 | 06:40 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Cam install. Assembly lube? (Coyote1800cc)
I smother the cam with assembly lube.
Old Jan 18, 2003 | 01:35 AM
rice_classic's Avatar
I use this too or I will just use motor oil or Vasoline (breaks down into oil as well).
1:Assembly Lube
2:Lithium grease
3:Vasoline
4:10w-30
Start with 1
Old Jan 18, 2003 | 11:07 AM
Farnsrocket's Avatar
Default Re: Cam install. Assembly lube? (rice_classic)
STP Oil treatment works great and sticks good too!
Old Jan 18, 2003 | 12:08 PM
Kataku2K3's Avatar
Default Re: Cam install. Assembly lube? (Farnsrocket)
Normally on cam installs i don't ever use assembly lube and it seems to work fine... I know it is recommended but I just lubricate everything with oil first, I do however use it when I assemble bottom ends... I either use the assembly lube pictured above^^ or Redline CV2...
Adam West
Northeast (Sales)
Jan 3, 2010 06:59 PM
Bwhit12
Sep 30, 2009 05:26 PM
dkboyny11
Apr 5, 2006 04:38 PM
an2ny888
Feb 20, 2005 06:06 AM
1.8Tities
Sep 25, 2002 04:47 PM
